[Qgis-user] QGIS slower on new, faster Linux machine
Andreas Neumann
a.neumann at carto.net
Wed Aug 17 12:44:01 PDT 2011
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I ran into similar issues with very large polygons. It was a clipping
problem. I believe it was fixed with a patched qt version in the windows
version, but if you use the original qt packages from ubuntu, the fix
wouldn't be present.
Are you using old or new symbology? I believe the issue is not present
any more in the new symbology.
If it still is - would you be willing to share the dataset with the
geometry that causes the problem? Marco perhaps could have a look at it.
btw: your machine seems very powerful to me. It really shouldn't be a
hardware issue.
Andreas
On 08/17/2011 08:47 PM, O wrote:
> An update:
> The problem seems to be with a single very long line layer (not sure how
> many points: I have not yet sorted out how to count them). When I zoom
> out to see the whole line, one of my eight cores reaches 100% and memory
> is nowhere close to being full, and QGIS grinds to a halt.
> I have had nothing like this kind of trouble in the past running QGIS on
> far less sophisticated hardware, although in all cases under Ubuntu or
> Wubi-installed Ubuntu rather than Debian, and on machines with NVIDIA
> cards. Contrary to what I said before, those machines had *less* VRAM
> than I have now (I have 1GB VRAM), and I doubt if VRAM has anything
> at all to do with issues of this kind.
> I am running QGIS 1.7.0.
> Any advice would be most welcome.
> O
> Qgis-user mailing list
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iQEcBAEBAgAGBQJOTBoAAAoJELiCsGDopvBCVBwH/R3FmD5cFtAdoDIXqW5cBzfP
gGYCddTMpuNekhoS3Qd6bm3toHQZ5mSSdaYZDaQZGAifUjZFby0iGM1j1Ni8FRmt
XhLsqukBqYtpNvTspvbW/gakSEORAEjNbPOuUtflQ0FnW5pGKt2946aq0J+E5ZzX
+zcM0MGRgb/boOR3uRe6tf4Tkx1PZDg6SHi8h2AnjgaicgPVvdk4koIZQNA97TDc
97/5wzFTiCd7aUuD0Gv+vHD3Y9cHdTmf7TuC3AMgKJm9oj42CL7cdM3dyPdj7xa/
MSJcJCcu5jUiXdrZI9VzSNnkQFd0JBVWnxji0ixmK+IbWuNE1s4GshrJCOt8OSE=
=yf5/
-----END PGP SIGNATURE-----
