[Qgis-user] Re: Testing the CSW plugin
aperi2007
aperi2007 at gmail.com
Mon Aug 22 08:40:14 PDT 2011
> May be you're right. In this case it is possible to enable this
>button with
> other type values.
should be great :)
> May be I'm wrong, but seems that there is no strict requirements which
> tag in metadata
> should specify is this WMS resource or not, also different servers
> store URL to this
> resource can be stored in different tags.
You are perfectly right.
The metadata ISO19115 allow many combinations.
But however also a "dataset" or "series" type (hierarchylevel)
could be have a WMS URL infact a simple metadata
could be of "dataset" or "series" type (hierarchy-level) and
give the information for a WMS/WFS/Download in the
section
distributionInfo -> transferOption
I guess that in the protocol field there is a OGC-WMS string more
probably the URL (if available) is forward a WMS server.
But of course this is only one of many availables configurations.
In GN, for example, there also the possibility to link a "dataset"
metadata to a "service" metadata.
Retrieving so the info on the WMS url (from service) and the idlayer
(from dataset).
This combination will allow to add not only a WMS to wms list, but it
allow also to add directly a wms layer to the canvas.
But of course this is a very special and complex configuration.
Il 22/08/2011 17:12, Alexander Bruy ha scritto:
> 2011/8/22 Andrea Peri<aperi2007 at gmail.com>:
>>> The "Add WMS" button enabled only for records with "liveData" type.
>> Yes, this is clearly readable in your docs.
>> Unfortunately, GeoNetwork's CSW populate the "type" of the csw response
>> using the
>> value from the tag "hierarchy-level".
>> This value has a set of availables values, but there isn't the "liveData"
>> value as optional value.
>> So I'm not able to produce a good metadata able to activate this very
>> interesting function.
>> From a quick search I guess the "liveData" is available only in the
>> esri-systems.
>> So perhaps is an enhancement of the esri-profile.
> May be you're right. In this case it is possible to enable this button with
> other type values.
>> In the ISO19115/19139 specs for the tag HierarchyLevel (for the csw-type
>> tag) could be the "service" value.
> Ok, I'll update plugin to handle also "service" type.
>> However I like better understand why is need to have only the metadata
>> "liveData" as WMSadd-able.
>> I guess, instead, that every metadata having an URL and a protocol named
>> OGC-WMS could be a good candidate to have the "AddWMS" button available.
> tag in metadata
> store URL to this
