[Qgis-user] Table manager: cannot delete several fields at once
Borys Jurgiel lists at borysjurgiel.pl
Tue Aug 23 03:21:02 PDT 2011
Fixed in 0.3.7
Note: there are two series: 0.3.7 for QGIS 1.7 only and 0.2.x for older
versions. I didn't backport the fix to old series, as it's not critical.
The 0.3 series was also tagged as 'experimental'. I've just removed the tag as
I think it's stable enough now.
Dnia wtorek, 23 sierpnia 2011 o 09:13:22 Florent LEVAVASSEUR napisaƂ(a):
> I have the same issue but only if I select several fields with the SHIFT
> key. If I select fields with the CTRL key, it works and the selected
> fields are deleted.
> On 22/08/11 21:46, Agustin Lobo wrote:
> > Even if several fields can be selected, after clicking on Delete
> > only the first one is deleted (actually the user is prompted on making
> > sure the first selected field has to be deleted). I understand this is a
> > bug, am I wrong?
> > Agus
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
