[Qgis-user] Error using clipper with mask option
Giuseppe Sucameli sucameli at faunalia.it
Tue Aug 23 08:41:25 PDT 2011
On Tue, Aug 23, 2011 at 5:35 PM, Jaime Palalane <mitasjp at gmail.com> wrote:
> I tried to use the clipper function, under Raster Menu (GDAL plugin),  with
> *mask option* but it returns the error below
this problem should be fixed times ago.
 Ocorreu um erro durante a execução do seguinte código Python: (An error
> occurred with the execution of the following Python code:)
What version of the GdalTools plugin are you using?
You can find this information under Raster->About GdalTools.
Thanks a lot.
Regards.
> Traceback (most recent call last):
>   File
> "/usr/share/qgis/python/plugins/GdalTools/tools/widgetPluginBase.py", line
> 27, in someValueChanged
>     self.emit(SIGNAL("valuesChanged(const QStringList &)"),
> self.getArguments())
>   File "/usr/share/qgis/python/plugins/GdalTools/tools/doClipper.py", line
> 105, in getArguments
>     return self.getArgsModeMask()
> 143, in getArgsModeMask
>     if self.alphaBandCheck.isChecked():
> AttributeError: 'GdalToolsDialog' object has no attribute 'alphaBandCheck'
> Versão do Python:
> 2.7.1+ (r271:86832, Apr 11 2011, 18:37:12)
> [GCC 4.5.2]
> Versão do QGIS:
> 1.7.0-Wroclaw Wroclaw, exported
> Caminho para o Python: ['/usr/share/qgis/python', '/home/jp/.qgis/python',
> '/home/jp/.qgis/python/plugins', '/usr/share/qgis/python/plugins',
> '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2',
> '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
> '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages/Numeric',
> '/usr/lib/python2.7/dist-packages/PIL',
> '/usr/lib/pymodules/python2.7/gtk-2.0',
> '/usr/lib/python2.7/dist-packages/gst-0.10',
> '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7',
> '/usr/lib/pymodules/python2.7/ubuntuone-client',
> '/usr/lib/pymodules/python2.7/ubuntuone-storage-protocol',
> '/usr/lib/pymodules/python2.7/ubuntuone-control-panel',
> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
> '/usr/share/qgis/python/plugins/fTools/tools']
> Qgis-user mailing list
Giuseppe Sucameli
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110823/43514a1f/attachment.html>
