[Qgis-user] Error using clipper with mask option
Jaime Palalane
mitasjp at gmail.com
Tue Aug 23 08:53:42 PDT 2011
It is a bit strange because when I access "About GdalTools" it is
written "*Version 1.2.26*" and in the following line "*using GDAL
v1.8.0*" (translated from Portuguese "usando GDAL v1.8.0"). What is the
correct version? I am an Ubuntu 11.04 user.
Thanks!
Jaime
On 23-08-2011 17:41, Giuseppe Sucameli wrote:
> Hi,
> On Tue, Aug 23, 2011 at 5:35 PM, Jaime Palalane <mitasjp at gmail.com
> <mailto:mitasjp at gmail.com>> wrote:
> I tried to use the clipper function, under Raster Menu (GDAL
> plugin), with *mask option* but it returns the error below
> this problem should be fixed times ago.
> Ocorreu um erro durante a execução do seguinte código Python: (An
> error occurred with the execution of the following Python code:)
> What version of the GdalTools plugin are you using?
> You can find this information under Raster->About GdalTools.
> Thanks a lot.
> Regards.
> Traceback (most recent call last):
> File
> "/usr/share/qgis/python/plugins/GdalTools/tools/widgetPluginBase.py",
> line 27, in someValueChanged
> self.emit(SIGNAL("valuesChanged(const QStringList &)"),
> self.getArguments())
> File
> "/usr/share/qgis/python/plugins/GdalTools/tools/doClipper.py",
> line 105, in getArguments
> return self.getArgsModeMask()
> File
> line 143, in getArgsModeMask
> if self.alphaBandCheck.isChecked():
> AttributeError: 'GdalToolsDialog' object has no attribute
> 'alphaBandCheck'
> Versão do Python:
> 2.7.1+ (r271:86832, Apr 11 2011, 18:37:12)
> [GCC 4.5.2]
> Versão do QGIS:
> 1.7.0-Wroclaw Wroclaw, exported
> Caminho para o Python: ['/usr/share/qgis/python',
> '/home/jp/.qgis/python', '/home/jp/.qgis/python/plugins',
> '/usr/share/qgis/python/plugins', '/usr/lib/python2.7',
> '/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk',
> '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload',
> '/usr/local/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages/Numeric',
> '/usr/lib/python2.7/dist-packages/PIL',
> '/usr/lib/pymodules/python2.7/gtk-2.0',
> '/usr/lib/python2.7/dist-packages/gst-0.10',
> '/usr/lib/python2.7/dist-packages/gtk-2.0',
> '/usr/lib/pymodules/python2.7',
> '/usr/lib/pymodules/python2.7/ubuntuone-client',
> '/usr/lib/pymodules/python2.7/ubuntuone-storage-protocol',
> '/usr/lib/pymodules/python2.7/ubuntuone-control-panel',
> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
> '/usr/share/qgis/python/plugins/fTools/tools']
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> Giuseppe Sucameli
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110823/9243c98f/attachment.html>
