[Qgis-user] Error using clipper with mask option
Giuseppe Sucameli
sucameli at faunalia.it
Tue Aug 23 09:52:28 PDT 2011
Hi Jaime,
On Tue, Aug 23, 2011 at 5:53 PM, Jaime Palalane <mitasjp at gmail.com> wrote:
> It is a bit strange because when I access "About GdalTools" it is written "
> *Version 1.2.26*" and in the following line "*using GDAL v1.8.0*"
> (translated from Portuguese "usando GDAL v1.8.0"). What is the correct
> version? I am an Ubuntu 11.04 user.
It's right because GdalTools plugin use the GDAL library.
The GdalTools plugin version is 1.2.26, the GDAL lib version is 1.8.
You will be able to update the GdalTools plugin enabling experimental
plugins
though the Python Plugin Installer (look at the Options tab).
The version 1.2.27 is available, install it and try again.
Regards.
> Thanks!
> Jaime
> On 23-08-2011 17:41, Giuseppe Sucameli wrote:
> Hi,
> On Tue, Aug 23, 2011 at 5:35 PM, Jaime Palalane <mitasjp at gmail.com> wrote:
>> I tried to use the clipper function, under Raster Menu (GDAL plugin),
>> with *mask option* but it returns the error below
> this problem should be fixed times ago.
> Ocorreu um erro durante a execução do seguinte código Python: (An error
>> occurred with the execution of the following Python code:)
> What version of the GdalTools plugin are you using?
> You can find this information under Raster->About GdalTools.
> Thanks a lot.
> Regards.
>> Traceback (most recent call last):
>> File
>> "/usr/share/qgis/python/plugins/GdalTools/tools/widgetPluginBase.py", line
>> 27, in someValueChanged
>> self.emit(SIGNAL("valuesChanged(const QStringList &)"),
>> self.getArguments())
>> File "/usr/share/qgis/python/plugins/GdalTools/tools/doClipper.py", line
>> 105, in getArguments
>> return self.getArgsModeMask()
>> 143, in getArgsModeMask
>> if self.alphaBandCheck.isChecked():
>> AttributeError: 'GdalToolsDialog' object has no attribute 'alphaBandCheck'
>> Versão do Python:
>> 2.7.1+ (r271:86832, Apr 11 2011, 18:37:12)
>> [GCC 4.5.2]
>> Versão do QGIS:
>> 1.7.0-Wroclaw Wroclaw, exported
>> Caminho para o Python: ['/usr/share/qgis/python', '/home/jp/.qgis/python',
>> '/home/jp/.qgis/python/plugins', '/usr/share/qgis/python/plugins',
>> '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2',
>> '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
>> '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages',
>> '/usr/lib/python2.7/dist-packages',
>> '/usr/lib/python2.7/dist-packages/Numeric',
>> '/usr/lib/python2.7/dist-packages/PIL',
>> '/usr/lib/pymodules/python2.7/gtk-2.0',
>> '/usr/lib/python2.7/dist-packages/gst-0.10',
>> '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7',
>> '/usr/lib/pymodules/python2.7/ubuntuone-client',
>> '/usr/lib/pymodules/python2.7/ubuntuone-storage-protocol',
>> '/usr/lib/pymodules/python2.7/ubuntuone-control-panel',
>> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
>> '/usr/share/qgis/python/plugins/fTools/tools']
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Giuseppe Sucameli
Giuseppe Sucameli
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110823/d03d4caa/attachment.html>
