[Qgis-user] Error using clipper with mask option
Jaime Palalane mitasjp at gmail.com
Wed Aug 24 08:35:29 PDT 2011
Thank you for this explanation. The mask fuction worked after updating
the GdalTools.
Regards
Jaime
On 23-08-2011 18:52, Giuseppe Sucameli wrote:
> Hi Jaime,
> On Tue, Aug 23, 2011 at 5:53 PM, Jaime Palalane <mitasjp at gmail.com
> <mailto:mitasjp at gmail.com>> wrote:
>     It is a bit strange because when I access "About GdalTools" it is
>     written "*Version 1.2.26*" and in the following line "*using GDAL
>     v1.8.0*" (translated from Portuguese "usando GDAL v1.8.0"). What
>     is the correct version? I am an Ubuntu 11.04 user.
> It's right because GdalTools plugin use the GDAL library.
> The GdalTools plugin version is 1.2.26, the GDAL lib version is 1.8.
> You will be able to update the GdalTools plugin enabling experimental
> plugins
> though the Python Plugin Installer (look at the Options tab).
> The version 1.2.27 is available, install it and try again.
> Regards.
>     Thanks!
>     Jaime
>     On 23-08-2011 17:41, Giuseppe Sucameli wrote:
>>     Hi,
>>     On Tue, Aug 23, 2011 at 5:35 PM, Jaime Palalane
>>     <mitasjp at gmail.com <mailto:mitasjp at gmail.com>> wrote:
>>         I tried to use the clipper function, under Raster Menu (GDAL
>>         plugin),  with *mask option* but it returns the error below
>>     this problem should be fixed times ago.
>>         Ocorreu um erro durante a execução do seguinte código Python:
>>         (An error occurred with the execution of the following Python
>>         code:)
>>     What version of the GdalTools plugin are you using?
>>     You can find this information under Raster->About GdalTools.
>>     Thanks a lot.
>>     Regards.
>>         Traceback (most recent call last):
>>           File
>>         "/usr/share/qgis/python/plugins/GdalTools/tools/widgetPluginBase.py",
>>         line 27, in someValueChanged
>>             self.emit(SIGNAL("valuesChanged(const QStringList &)"),
>>         self.getArguments())
>>           File
>>         "/usr/share/qgis/python/plugins/GdalTools/tools/doClipper.py", line
>>         105, in getArguments
>>             return self.getArgsModeMask()
>>           File
>>         143, in getArgsModeMask
>>             if self.alphaBandCheck.isChecked():
>>         AttributeError: 'GdalToolsDialog' object has no attribute
>>         'alphaBandCheck'
>>         Versão do Python:
>>         2.7.1+ (r271:86832, Apr 11 2011, 18:37:12)
>>         [GCC 4.5.2]
>>         Versão do QGIS:
>>         1.7.0-Wroclaw Wroclaw, exported
>>         Caminho para o Python: ['/usr/share/qgis/python',
>>         '/home/jp/.qgis/python', '/home/jp/.qgis/python/plugins',
>>         '/usr/share/qgis/python/plugins', '/usr/lib/python2.7',
>>         '/usr/lib/python2.7/plat-linux2',
>>         '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
>>         '/usr/lib/python2.7/lib-dynload',
>>         '/usr/local/lib/python2.7/dist-packages',
>>         '/usr/lib/python2.7/dist-packages',
>>         '/usr/lib/python2.7/dist-packages/Numeric',
>>         '/usr/lib/python2.7/dist-packages/PIL',
>>         '/usr/lib/pymodules/python2.7/gtk-2.0',
>>         '/usr/lib/python2.7/dist-packages/gst-0.10',
>>         '/usr/lib/python2.7/dist-packages/gtk-2.0',
>>         '/usr/lib/pymodules/python2.7',
>>         '/usr/lib/pymodules/python2.7/ubuntuone-client',
>>         '/usr/lib/pymodules/python2.7/ubuntuone-storage-protocol',
>>         '/usr/lib/pymodules/python2.7/ubuntuone-control-panel',
>>         '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
>>         '/usr/share/qgis/python/plugins/fTools/tools']
>>         _______________________________________________
>>         Qgis-user mailing list
>>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>         http://lists.osgeo.org/mailman/listinfo/qgis-user
>>     Giuseppe Sucameli
> Giuseppe Sucameli
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110824/71cda328/attachment.html>
