[Qgis-user] Error using clipper with mask option
Robert Nuske rnuske at gwdg.de
Tue Aug 23 10:10:12 PDT 2011
Hi Giuseppe
I had the same problme as Jaime.
Tried your hint and it actually works now as expected. Thanks!
> You will be able to update the GdalTools plugin enabling experimental
> plugins
> though the Python Plugin Installer (look at the Options tab).
> The version 1.2.27 is available, install it and try again.
Do you know when version 1.2.27 will be not experimental anymore?
cheers,
  robert
> > On 23-08-2011 17:41, Giuseppe Sucameli wrote:
> > Hi,
> > On Tue, Aug 23, 2011 at 5:35 PM, Jaime Palalane <mitasjp at gmail.com> wrote:
> >>  I tried to use the clipper function, under Raster Menu (GDAL plugin),
> >> with *mask option* but it returns the error below
> > this problem should be fixed times ago.
> >   Ocorreu um erro durante a execução do seguinte código Python: (An error
> >> occurred with the execution of the following Python code:)
> > What version of the GdalTools plugin are you using?
> > You can find this information under Raster->About GdalTools.
> > Thanks a lot.
> > Regards.
> >> Traceback (most recent call last):
> >>   File
> >> "/usr/share/qgis/python/plugins/GdalTools/tools/widgetPluginBase.py",
> >> line 27, in someValueChanged
> >>     self.emit(SIGNAL("valuesChanged(const QStringList &)"),
> >> self.getArguments())
> >>   File "/usr/share/qgis/python/plugins/GdalTools/tools/doClipper.py",
> >>   line
> >> 105, in getArguments
> >>     return self.getArgsModeMask()
> >>   line
> >> 143, in getArgsModeMask
> >>     if self.alphaBandCheck.isChecked():
> >> AttributeError: 'GdalToolsDialog' object has no attribute
> >> 'alphaBandCheck'
> >> Versão do Python:
> >> 2.7.1+ (r271:86832, Apr 11 2011, 18:37:12)
> >> [GCC 4.5.2]
> >> Versão do QGIS:
> >> 1.7.0-Wroclaw Wroclaw, exported
> >> Caminho para o Python: ['/usr/share/qgis/python',
> >> '/home/jp/.qgis/python', '/home/jp/.qgis/python/plugins',
> >> '/usr/share/qgis/python/plugins', '/usr/lib/python2.7',
> >> '/usr/lib/python2.7/plat-linux2',
> >> '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
> >> '/usr/lib/python2.7/lib-dynload',
> >> '/usr/local/lib/python2.7/dist-packages',
> >> '/usr/lib/python2.7/dist-packages',
> >> '/usr/lib/python2.7/dist-packages/Numeric',
> >> '/usr/lib/python2.7/dist-packages/PIL',
> >> '/usr/lib/pymodules/python2.7/gtk-2.0',
> >> '/usr/lib/python2.7/dist-packages/gst-0.10',
> >> '/usr/lib/python2.7/dist-packages/gtk-2.0',
> >> '/usr/lib/pymodules/python2.7',
> >> '/usr/lib/pymodules/python2.7/ubuntuone-client',
> >> '/usr/lib/pymodules/python2.7/ubuntuone-storage-protocol',
> >> '/usr/lib/pymodules/python2.7/ubuntuone-control-panel',
> >> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
> >> '/usr/share/qgis/python/plugins/fTools/tools']
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Giuseppe Sucameli
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110823/0a5739fd/attachment.html>
