[Qgis-user] Pgvs Versioning plugin 0.9.3
Nomeneta Saili nome.saili at gmail.com
Tue Aug 23 16:12:27 PDT 2011
Hi people,
After installing this tool i was able to version one of my layers.
However when i tried to use it again it says i need to install pgvs on
my database.
When i connected to my PostGIS database it had the version schema and
the version table under it. However i think things went wrong when i
deleted the version layer from the add postGIS table open dialog
thinking it will not be a problem.
When i was looking at installing pgvs on my database i found that the
schema for 'Version' is still on my database as well as all the
functions specified in http://www.kappasys.ch/cms/index.php?id=23
Do i delete this 'Version' schema and start again?.  Dr. Horst. This
is a wonderful tool btw. Thanks.
On Tue, Aug 23, 2011 at 6:47 AM,  <qgis-user-request at lists.osgeo.org> wrote:
> Send Qgis-user mailing list submissions to
>        qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>        http://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>        qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>   1. Re: Error using clipper with mask option (Giuseppe Sucameli)
>   2. Re: Error using clipper with mask option (Robert Nuske)
> Message: 1
> Date: Tue, 23 Aug 2011 18:52:28 +0200
> From: Giuseppe Sucameli <sucameli at faunalia.it>
> Subject: Re: [Qgis-user] Error using clipper with mask option
> To: Jaime Palalane <mitasjp at gmail.com>
> Cc: qgis-user at lists.osgeo.org
> Message-ID:
>        <CAA6k8-+WZwWRBOwEWOUs6GEsnQ=L9PXWV_XhLnROSkctDQNyUQ at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Hi Jaime,
> On Tue, Aug 23, 2011 at 5:53 PM, Jaime Palalane <mitasjp at gmail.com> wrote:
>> It is a bit strange because when I access "About GdalTools" it is written "
>> *Version 1.2.26*" and in the following line "*using GDAL v1.8.0*"
>> (translated from Portuguese "usando GDAL v1.8.0"). What is the correct
>> version? I am an Ubuntu 11.04 user.
> It's right because GdalTools plugin use the GDAL library.
> The GdalTools plugin version is 1.2.26, the GDAL lib version is 1.8.
> You will be able to update the GdalTools plugin enabling experimental
> plugins
> though the Python Plugin Installer (look at the Options tab).
> The version 1.2.27 is available, install it and try again.
> Regards.
>> Thanks!
>> Jaime
>> On 23-08-2011 17:41, Giuseppe Sucameli wrote:
>> Hi,
>> On Tue, Aug 23, 2011 at 5:35 PM, Jaime Palalane <mitasjp at gmail.com> wrote:
>>>  I tried to use the clipper function, under Raster Menu (GDAL plugin),
>>> with *mask option* but it returns the error below
>> this problem should be fixed times ago.
>>   Ocorreu um erro durante a execução do seguinte código Python: (An error
>>> occurred with the execution of the following Python code:)
>> What version of the GdalTools plugin are you using?
>> You can find this information under Raster->About GdalTools.
>> Thanks a lot.
>> Regards.
>>> Traceback (most recent call last):
>>>   File
>>> "/usr/share/qgis/python/plugins/GdalTools/tools/widgetPluginBase.py", line
>>> 27, in someValueChanged
>>>     self.emit(SIGNAL("valuesChanged(const QStringList &)"),
>>> self.getArguments())
>>>   File "/usr/share/qgis/python/plugins/GdalTools/tools/doClipper.py", line
>>> 105, in getArguments
>>>     return self.getArgsModeMask()
>>> 143, in getArgsModeMask
>>>     if self.alphaBandCheck.isChecked():
>>> AttributeError: 'GdalToolsDialog' object has no attribute 'alphaBandCheck'
>>> Versão do Python:
>>> 2.7.1+ (r271:86832, Apr 11 2011, 18:37:12)
>>> [GCC 4.5.2]
>>> Versão do QGIS:
>>> 1.7.0-Wroclaw Wroclaw, exported
>>> Caminho para o Python: ['/usr/share/qgis/python', '/home/jp/.qgis/python',
>>> '/home/jp/.qgis/python/plugins', '/usr/share/qgis/python/plugins',
>>> '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2',
>>> '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
>>> '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages',
>>> '/usr/lib/python2.7/dist-packages',
>>> '/usr/lib/python2.7/dist-packages/Numeric',
>>> '/usr/lib/python2.7/dist-packages/PIL',
>>> '/usr/lib/pymodules/python2.7/gtk-2.0',
>>> '/usr/lib/python2.7/dist-packages/gst-0.10',
>>> '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7',
>>> '/usr/lib/pymodules/python2.7/ubuntuone-client',
>>> '/usr/lib/pymodules/python2.7/ubuntuone-storage-protocol',
>>> '/usr/lib/pymodules/python2.7/ubuntuone-control-panel',
>>> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
>>> '/usr/share/qgis/python/plugins/fTools/tools']
>>> Qgis-user at lists.osgeo.org
>> Giuseppe Sucameli
> Giuseppe Sucameli
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20110823/d03d4caa/attachment-0001.html
> Message: 2
> Date: Tue, 23 Aug 2011 19:10:12 +0200
> From: Robert Nuske <rnuske at gwdg.de>
> To: qgis-user at lists.osgeo.org
> Message-ID: <201108231910.12654.rnuske at gwdg.de>
> Hi Giuseppe
> I had the same problme as Jaime.
> Tried your hint and it actually works now as expected. Thanks!
>> plugins
> Do you know when version 1.2.27 will be not experimental anymore?
> cheers,
>  robert
>> > Hi,
>> > Thanks a lot.
>> > Regards.
>> >>   File
>> >> line 27, in someValueChanged
>> >>   line
>> >>   line
>> >> 'alphaBandCheck'
>> >> Versão do Python:
>> >> [GCC 4.5.2]
>> >> Versão do QGIS:
>> >> '/home/jp/.qgis/python', '/home/jp/.qgis/python/plugins',
>> >> '/usr/share/qgis/python/plugins', '/usr/lib/python2.7',
>> > Giuseppe Sucameli
> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20110823/0a5739fd/attachment.html
> End of Qgis-user Digest, Vol 66, Issue 42
