[Qgis-user] Pgvs Versioning plugin 0.9.3
Horst Düster horst.duester at kappasys.ch
Wed Aug 24 01:10:20 PDT 2011
Hi Nomeneta
Have a look on the table and view permissions.
Horst
Am 24.08.2011 01:12, schrieb Nomeneta Saili:
> Hi people,
> After installing this tool i was able to version one of my layers.
> However when i tried to use it again it says i need to install pgvs on
> my database.
> When i connected to my PostGIS database it had the version schema and
> the version table under it. However i think things went wrong when i
> deleted the version layer from the add postGIS table open dialog
> thinking it will not be a problem.
> When i was looking at installing pgvs on my database i found that the
> schema for 'Version' is still on my database as well as all the
> functions specified in http://www.kappasys.ch/cms/index.php?id=23
> Do i delete this 'Version' schema and start again?.  Dr. Horst. This
> is a wonderful tool btw. Thanks.
> On Tue, Aug 23, 2011 at 6:47 AM,<qgis-user-request at lists.osgeo.org>  wrote:
>> Send Qgis-user mailing list submissions to
>>         qgis-user at lists.osgeo.org
>> To subscribe or unsubscribe via the World Wide Web, visit
>>         http://lists.osgeo.org/mailman/listinfo/qgis-user
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>>         qgis-user-owner at lists.osgeo.org
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of Qgis-user digest..."
>> Today's Topics:
>>    1. Re: Error using clipper with mask option (Giuseppe Sucameli)
>>    2. Re: Error using clipper with mask option (Robert Nuske)
>> Message: 1
>> Date: Tue, 23 Aug 2011 18:52:28 +0200
>> From: Giuseppe Sucameli<sucameli at faunalia.it>
>> Subject: Re: [Qgis-user] Error using clipper with mask option
>> To: Jaime Palalane<mitasjp at gmail.com>
>> Cc: qgis-user at lists.osgeo.org
>> Message-ID:
>>         <CAA6k8-+WZwWRBOwEWOUs6GEsnQ=L9PXWV_XhLnROSkctDQNyUQ at mail.gmail.com>
>> Content-Type: text/plain; charset="iso-8859-1"
>> Hi Jaime,
>> On Tue, Aug 23, 2011 at 5:53 PM, Jaime Palalane<mitasjp at gmail.com>  wrote:
>>> It is a bit strange because when I access "About GdalTools" it is written "
>>> *Version 1.2.26*" and in the following line "*using GDAL v1.8.0*"
>>> (translated from Portuguese "usando GDAL v1.8.0"). What is the correct
>>> version? I am an Ubuntu 11.04 user.
>> It's right because GdalTools plugin use the GDAL library.
>> The GdalTools plugin version is 1.2.26, the GDAL lib version is 1.8.
>> You will be able to update the GdalTools plugin enabling experimental
>> plugins
>> though the Python Plugin Installer (look at the Options tab).
>> The version 1.2.27 is available, install it and try again.
>> Regards.
>>> Thanks!
>>> Jaime
>>> On 23-08-2011 17:41, Giuseppe Sucameli wrote:
>>> Hi,
>>> On Tue, Aug 23, 2011 at 5:35 PM, Jaime Palalane<mitasjp at gmail.com>  wrote:
>>>>   I tried to use the clipper function, under Raster Menu (GDAL plugin),
>>>> with *mask option* but it returns the error below
>>> this problem should be fixed times ago.
>>>    Ocorreu um erro durante a execução do seguinte código Python: (An error
>>>> occurred with the execution of the following Python code:)
>>> What version of the GdalTools plugin are you using?
>>> You can find this information under Raster->About GdalTools.
>>> Thanks a lot.
>>> Regards.
>>>> Traceback (most recent call last):
>>>>    File
>>>> "/usr/share/qgis/python/plugins/GdalTools/tools/widgetPluginBase.py", line
>>>> 27, in someValueChanged
>>>>      self.emit(SIGNAL("valuesChanged(const QStringList&)"),
>>>> self.getArguments())
>>>>    File "/usr/share/qgis/python/plugins/GdalTools/tools/doClipper.py", line
>>>> 105, in getArguments
>>>>      return self.getArgsModeMask()
>>>> 143, in getArgsModeMask
>>>>      if self.alphaBandCheck.isChecked():
>>>> AttributeError: 'GdalToolsDialog' object has no attribute 'alphaBandCheck'
>>>> Versão do Python:
>>>> 2.7.1+ (r271:86832, Apr 11 2011, 18:37:12)
>>>> [GCC 4.5.2]
>>>> Versão do QGIS:
>>>> 1.7.0-Wroclaw Wroclaw, exported
>>>> Caminho para o Python: ['/usr/share/qgis/python', '/home/jp/.qgis/python',
>>>> '/home/jp/.qgis/python/plugins', '/usr/share/qgis/python/plugins',
>>>> '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2',
>>>> '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
>>>> '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages',
>>>> '/usr/lib/python2.7/dist-packages',
>>>> '/usr/lib/python2.7/dist-packages/Numeric',
>>>> '/usr/lib/python2.7/dist-packages/PIL',
>>>> '/usr/lib/pymodules/python2.7/gtk-2.0',
>>>> '/usr/lib/python2.7/dist-packages/gst-0.10',
>>>> '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7',
>>>> '/usr/lib/pymodules/python2.7/ubuntuone-client',
>>>> '/usr/lib/pymodules/python2.7/ubuntuone-storage-protocol',
>>>> '/usr/lib/pymodules/python2.7/ubuntuone-control-panel',
>>>> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
>>>> '/usr/share/qgis/python/plugins/fTools/tools']
>>>> _______________________________________________
>>>> Qgis-user at lists.osgeo.org
>>> Giuseppe Sucameli
>> Giuseppe Sucameli
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20110823/d03d4caa/attachment-0001.html
>> Message: 2
>> Date: Tue, 23 Aug 2011 19:10:12 +0200
>> From: Robert Nuske<rnuske at gwdg.de>
>> To: qgis-user at lists.osgeo.org
>> Message-ID:<201108231910.12654.rnuske at gwdg.de>
>> Hi Giuseppe
>> I had the same problme as Jaime.
>> Tried your hint and it actually works now as expected. Thanks!
>>> plugins
>> Do you know when version 1.2.27 will be not experimental anymore?
>> cheers,
>>   robert
>>>> Hi,
>>>> Thanks a lot.
>>>> Regards.
>>>>>    File
>>>>> line 27, in someValueChanged
>>>>>    line
>>>>>    line
>>>>> 'alphaBandCheck'
>>>>> Versão do Python:
>>>>> [GCC 4.5.2]
>>>>> Versão do QGIS:
>>>>> '/home/jp/.qgis/python', '/home/jp/.qgis/python/plugins',
>>>>> '/usr/share/qgis/python/plugins', '/usr/lib/python2.7',
>>>> Giuseppe Sucameli
>> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20110823/0a5739fd/attachment.html
>> End of Qgis-user Digest, Vol 66, Issue 42
Dr. Horst Düster
Burchacker 6
CH-4556 Aeschi
Tel.: +41 (0) 62 961 03 74
Mobil: +41 (0) 76 408 51 06
eMail: horst.duester at kappasys.ch
skype: horstduester
Web: www.kappasys.ch
