[Qgis-user] RE: Newbie to GIS and QGIS
Nomeneta Saili nome.saili at gmail.com
Wed Aug 24 13:15:18 PDT 2011
Hi Jel,
It might also help to just go through the basis/fundamental of GIS
which will help you in learning/understanding the software. Things
like the layer concept. Vector and Raster data models. Spatial objects
with tabular data, spatial reference systems/coordinate systems etc.
>From my experience. Spatial reference system is overlooked by many new
GIS people but the basis of GIS is really the spatial component. I
have seen people worked on and digitized on layers with different
spatial reference systems unknowingly and when they try to put them
together they get messed up. Luckily these days a lot of software do
on the fly projections but its still important to understand Spatial
reference systems or at least keep your data to a consistent spatial
reference system.
Going through the basics would also allow you see and do more with GIS
apart from just making static maps as you were looking at.
All the best with your en devours
On Wed, Aug 24, 2011 at 7:31 AM,  <qgis-user-request at lists.osgeo.org> wrote:
> Send Qgis-user mailing list submissions to
>        qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>        http://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>        qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>   1. Re: Error using clipper with mask option (Jaime Palalane)
>   2. RE: Newbie to GIS and QGIS (Jel Coward)
>   3. RE: [Qgis-developer] Re: [Qgis-user] Android QGIS download
>      Link (Duarte Carreira)
> Message: 1
> Date: Wed, 24 Aug 2011 17:35:29 +0200
> From: Jaime Palalane <mitasjp at gmail.com>
> Subject: Re: [Qgis-user] Error using clipper with mask option
> To: Giuseppe Sucameli <sucameli at faunalia.it>
> Cc: qgis-user at lists.osgeo.org
> Message-ID: <4E551A41.3010401 at gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Thank you for this explanation. The mask fuction worked after updating
> the GdalTools.
> Regards
> Jaime
> On 23-08-2011 18:52, Giuseppe Sucameli wrote:
>> Hi Jaime,
>> On Tue, Aug 23, 2011 at 5:53 PM, Jaime Palalane <mitasjp at gmail.com
>> <mailto:mitasjp at gmail.com>> wrote:
>>     It is a bit strange because when I access "About GdalTools" it is
>>     written "*Version 1.2.26*" and in the following line "*using GDAL
>>     v1.8.0*" (translated from Portuguese "usando GDAL v1.8.0"). What
>>     is the correct version? I am an Ubuntu 11.04 user.
>> It's right because GdalTools plugin use the GDAL library.
>> The GdalTools plugin version is 1.2.26, the GDAL lib version is 1.8.
>> You will be able to update the GdalTools plugin enabling experimental
>> plugins
>> though the Python Plugin Installer (look at the Options tab).
>> The version 1.2.27 is available, install it and try again.
>> Regards.
>>     Thanks!
>>     Jaime
>>     On 23-08-2011 17:41, Giuseppe Sucameli wrote:
>>>     Hi,
>>>     On Tue, Aug 23, 2011 at 5:35 PM, Jaime Palalane
>>>     <mitasjp at gmail.com <mailto:mitasjp at gmail.com>> wrote:
>>>         I tried to use the clipper function, under Raster Menu (GDAL
>>>         plugin),  with *mask option* but it returns the error below
>>>     this problem should be fixed times ago.
>>>         Ocorreu um erro durante a execução do seguinte código Python:
>>>         (An error occurred with the execution of the following Python
>>>         code:)
>>>     What version of the GdalTools plugin are you using?
>>>     You can find this information under Raster->About GdalTools.
>>>     Thanks a lot.
>>>     Regards.
>>>         Traceback (most recent call last):
>>>           File
>>>         "/usr/share/qgis/python/plugins/GdalTools/tools/widgetPluginBase.py",
>>>         line 27, in someValueChanged
>>>             self.emit(SIGNAL("valuesChanged(const QStringList &)"),
>>>         self.getArguments())
>>>           File
>>>         "/usr/share/qgis/python/plugins/GdalTools/tools/doClipper.py", line
>>>         105, in getArguments
>>>             return self.getArgsModeMask()
>>>           File
>>>         143, in getArgsModeMask
>>>             if self.alphaBandCheck.isChecked():
>>>         AttributeError: 'GdalToolsDialog' object has no attribute
>>>         'alphaBandCheck'
>>>         Versão do Python:
>>>         2.7.1+ (r271:86832, Apr 11 2011, 18:37:12)
>>>         [GCC 4.5.2]
>>>         Versão do QGIS:
>>>         1.7.0-Wroclaw Wroclaw, exported
>>>         Caminho para o Python: ['/usr/share/qgis/python',
>>>         '/home/jp/.qgis/python', '/home/jp/.qgis/python/plugins',
>>>         '/usr/share/qgis/python/plugins', '/usr/lib/python2.7',
>>>         '/usr/lib/python2.7/plat-linux2',
>>>         '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
>>>         '/usr/lib/python2.7/lib-dynload',
>>>         '/usr/local/lib/python2.7/dist-packages',
>>>         '/usr/lib/python2.7/dist-packages',
>>>         '/usr/lib/python2.7/dist-packages/Numeric',
>>>         '/usr/lib/python2.7/dist-packages/PIL',
>>>         '/usr/lib/pymodules/python2.7/gtk-2.0',
>>>         '/usr/lib/python2.7/dist-packages/gst-0.10',
>>>         '/usr/lib/python2.7/dist-packages/gtk-2.0',
>>>         '/usr/lib/pymodules/python2.7',
>>>         '/usr/lib/pymodules/python2.7/ubuntuone-client',
>>>         '/usr/lib/pymodules/python2.7/ubuntuone-storage-protocol',
>>>         '/usr/lib/pymodules/python2.7/ubuntuone-control-panel',
>>>         '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
>>>         '/usr/share/qgis/python/plugins/fTools/tools']
>>>         _______________________________________________
>>>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>     Giuseppe Sucameli
>> Giuseppe Sucameli
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20110824/71cda328/attachment-0001.html
> Message: 2
> Date: Wed, 24 Aug 2011 11:39:03 -0400
> From: Jel Coward <jel at wildmedic.org>
> Subject: RE: [Qgis-user] Newbie to GIS and QGIS
> To: qgis-user at lists.osgeo.org
> Message-ID:
>        <CAGwnjo_2=oEz+GkEx5mCge6pCX4Fgd382SgeHdH6KSVf1YBt3w at mail.gmail.com>
> Thank you all!  You are very welcoming.  Which is likely a big part of QGIS'
> community success.
> You have given me some great pointers and I will get to work on my learning.
> Cheers all
> Jel Coward
> Sent from a super-snazzy open-source Android phone.
> On Aug 24, 2011 6:26 AM, "Burton, Jim" <jim.burton at uk.ngrid.com> wrote:
>> Hi
>> I found your tutorial two days ago and thought it was a perfect example of
> promoting the use of GIS by the local community.
>> Regards
>> Jim Burton
>> Promap/GIS
>> Business Services
>> National Grid Property Ltd
>> National Grid
>> Workspace: A1 Property
>> National Grid House, Warwick Technology Park
>> Gallows Hill, Warwick, CV34 6DA
>> Tel: (Internal) 7474 5432 (External) +44 (0)1926 65 5432
>> Mob:
>> Address: jim.burton at uk.ngrid.com
>> -----Original Message-----
>> From: qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org] On Behalf Of Andrew Chapman
>> Sent: Wednesday, August 24, 2011 10:54 AM
>> To: jel at wildmedic.org
>> Subject: [Qgis-user] Newbie to GIS and QGIS
>> Hi Jel
>> You could also try looking at some of the tutorials that I've written for
> our website (http://www.dauntseydrainageboard.org.uk/html/tutorials.html).
>> These are aimed at United Kingdom parish councillors with no GIS or
> mapping background assumed, so they should work for almost anyone. All the
> maps used are available for free download.
>> I've used Windows and Ordnance Survey maps, but it should be relatively
> easy to follow using any version of QGIS or maps.
>> Andrew Chapman
>> This e-mail, and any attachments are strictly confidential and intended
> for
>> the addressee(s) only. The content may also contain legal, professional or
>> other privileged information. If you are not the intended recipient,
> please
>> notify the sender immediately and then delete the e-mail and any
>> attachments. You should not disclose, copy or take any action in reliance
>> on this transmission.
>> You may report the matter by calling us on 0800 085 4806.
>> Please ensure you have adequate virus protection before you open or detach
>> any documents from this transmission. The Group Companies do not accept
>> any liability for viruses. An e-mail reply to this address may be subject
>> to monitoring for operational reasons or lawful business practices.
>> For the registered information on the UK operating companies within the
>> National Grid group please use the attached link:
>> http://www.nationalgrid.com/corporate/legal/registeredoffices.htm
> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20110824/541fecd8/attachment-0001.html
> Message: 3
> Date: Wed, 24 Aug 2011 17:54:33 +0100
> From: Duarte Carreira <DCarreira at edia.pt>
> Subject: RE: [Qgis-developer] Re: [Qgis-user] Android QGIS download
>        Link
> To: Marco Bernasocchi <marco at bernawebdesign.ch>, M.E.Dodd
>        <m.e.dodd at open.ac.uk>
> Cc: 'qgis-user' <qgis-user at lists.osgeo.org>,    'qgis-developer'
>        <qgis-developer at lists.osgeo.org>
> Message-ID: <9DA6C5AFE0E78D48B7AC250D357F330213A6FF at beja012.edia.pt>
> Content-Type: text/plain; charset="us-ascii"
> Skipped content of type multipart/alternative-------------- next part --------------
> A non-text attachment was scrubbed...
> Type: image/png
> Desc: image001.png
> Url : http://lists.osgeo.org/pipermail/qgis-user/attachments/20110824/1078ba9a/image001.png
> End of Qgis-user Digest, Vol 66, Issue 48
