[Qgis-user] ArcGIS 10 and QGIS 1.7
Frank Sokolic sokolic at worldonline.co.za
Wed Aug 24 23:51:46 PDT 2011
Hi Christine,
I recently had a problem on Windows XP when I uninstalled 1.7, installed and uninstalled 1.6, and then installed QGIS 1.7 again. QGIS 1.7 kept on crashing and I eventually traced the problem to Trolltech keys in the registry. After removing Trolltech from the registry and then reinstalling 1.7 everything worked again.
Regards, Frank.
Sent:2011-08-24 21:48:16
To: qgis-user at lists.osgeo.org
Cc:
Subject: [Qgis-user] ArcGIS 10 and QGIS 1.7
Good evening all, have recently installed QGIS 1.7 on a Windows XP machine. It works really fine and I havn't met any difficulty until now. Thanks to this really engaged community ...  Should install a time limited version of ArcGIS 10  for educational purposes now on the same machine. Should have better done this in another succession, I know. Remember some troubles mentioned in this list with ArcGIS beeing installed after QGIS, as ArcGIS also uses Python.  Because I am now in worry about my clean QGIS installation, I am considering to uninstall QGIS 1.7, then install ArcGIS 10 and after all install QGIS 1.7 again.  May I expect the uninstall process of QGIS beeing complete enough not to get another trouble after a second installation of QGIS 1.7 ?  Thanks for an advice,and regards,Christine
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110825/eee20ee4/attachment.html>
