[Qgis-user] ArcGIS 10 and QGIS 1.7
Christine Schmidt
c.schmidt at geoTguide.de
Thu Aug 25 02:16:36 PDT 2011
hi,
thanks for your replies.
I remember a post in a QGIS forum rather than in this list to deal with that subject. But I could not find this thread any more. So, it's not only an assumption why I posted this question in the list, but I could not verify the circumstances and details of the original thread any more
Well, if that's not a known problem, I will have to try it on my own. Have already created an image of my harddisk, so I might roll back to a working QGIS 1.7 version in a bad case.
Christine
-----Ursprüngliche Nachricht-----
Von: "Andreas Neumann" <a.neumann at carto.net>
Gesendet: 25.08.2011 09:16:53
An: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] ArcGIS 10 and QGIS 1.7
> Hi,
> I don't think that QGIS' ArcGIS' python installations get into their
> ways. I think they both bring along their own local python
> installations. Do you have any indication that the two interfere with
> each other or is it just an assumption?
> It is quite common that machines have multiple python installations in
> parallel.
> Andreas
> On Thu, 25 Aug 2011 08:51:46 +0200, Frank Sokolic wrote:
>> Hi Christine,
>> I recently had a problem on Windows XP when I uninstalled 1.7,
>> installed and uninstalled 1.6, and then installed QGIS 1.7 again.
>> QGIS
>> 1.7 kept on crashing and I eventually traced the problem to Trolltech
>> keys in the registry. After removing Trolltech from the registry and
>> then reinstalling 1.7 everything worked again.
>> Regards, Frank.
>> FROM: c.schmidt at geoTguide.de
>> SENT:2011-08-24 21:48:16
>> TO: qgis-user at lists.osgeo.org
>> CC:
>> SUBJECT: [Qgis-user] ArcGIS 10 and QGIS 1.7
>> Good evening all,
>> have recently installed QGIS 1.7 on a Windows XP machine. It works
>> really fine and I havn't met any difficulty until now. Thanks to this
>> really engaged community ...
>> Should install a time limited version of ArcGIS 10 for educational
>> purposes now on the same machine. Should have better done this in
>> another succession, I know. Remember some troubles mentioned in this
>> list with ArcGIS beeing installed after QGIS, as ArcGIS also uses
>> Python.
>> Because I am now in worry about my clean QGIS installation, I am
>> considering to uninstall QGIS 1.7, then install ArcGIS 10 and after
>> all install QGIS 1.7 again.
>> May I expect the uninstall process of QGIS beeing complete enough not
>> to get another trouble after a second installation of QGIS 1.7 ?
>> Thanks for an advice,
>> and regards,
>> Christine
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
>_______________________________________________
>Qgis-user mailing list
>Qgis-user at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110825/6eb53db5/attachment.html>
