[Qgis-user] How Do I Set Field Calculator Units For Area
Alister Hood alister.hood at synergine.com
Wed Aug 31 16:18:13 PDT 2011
Hi there,
I *think* the area calculations are always in the unit for the layer's
CRS.  So you could either:
- find out what this unit is, and convert the areas to square feet by
multiplying by the correct factor, or
- convert the layer to a CRS which uses square feet.
N.B. there is a feature request to enable coordinate conversion in the
field calculator (although I didn't mention that it would be useful also
for area and length calculations).  See http://hub.qgis.org/issues/4078
Alister
> Date: Wed, 31 Aug 2011 11:18:32 -0500
> From: Andrew Novak <novak.andj at gmail.com>
> Subject: [Qgis-user] How Do I Set Field Calculator Units For Area
> 	Calcs?
> To: qgis-user at lists.osgeo.org
> Message-ID:
<CAO0Lqnon=aJMKGUb=BPacqxgn+PGn4G2vpe8sn=epxyT+pKtbw at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> The area calculations from my field calculator are in an unknown unit.
I
> simply want my units to be square feet. How can I set my units in the
field
> calculator??
