[Qgis-user] Re: Qgis-user Digest, Vol 67, Issue 1
Darrel Camden-Smith darrel at geoserveafrica.com
Wed Aug 31 23:18:11 PDT 2011
WRT Message 2 and the Profile from line tool I also had a problem
using this plugin. I am running Mac OSx ver 10.5.8. I have installed
QGIS and Python and the other suggested package installers. I found
the shapely tool and downloaded it tried to install but had no joy.
Used the Python 3.2 tool to try do that. Any ideas or help would be
greatly appreciated.
Darrel Camden-Smith
www.geoserveafrica.com
On 01 Sep 2011, at 6:00 PM, qgis-user-request at lists.osgeo.org wrote:
> Send Qgis-user mailing list submissions to
> 	qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	http://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>   1. RE: is it possible to print attribute tables? (Alister Hood)
>   2. Re: Profile Tool (Alister Hood)
>   3. RE: How Do I Set Field Calculator Units For Area (Alister Hood)
> Message: 1
> Date: Thu, 1 Sep 2011 09:37:07 +1200
> From: "Alister Hood" <alister.hood at synergine.com>
> Subject: RE: [Qgis-user] is it possible to print attribute tables?
> To: <qgis-user at lists.osgeo.org>
> Message-ID:
> 	<AAFD34025E073F47B5F892A97BAFFCAA5D0D8D at aklserver02.Synergine.local>
> Content-Type: text/plain;	charset="us-ascii"
> In case you don't know: you can also add an attribute table to a
> composer layout, but that won't be convenient if you want to print a
> long attribute table over multiple pages.
> Alister
>> Date: Wed, 31 Aug 2011 17:58:00 +0100
>> From: Alexandre Neto <senhor.neto at gmail.com>
>> Subject: Re: [Qgis-user] is it possible to print attribute tables?
>> To: Andrew Novak <novak.andj at gmail.com>
>> Cc: qgis-user at lists.osgeo.org
>> Message-ID:
> <CA+H0G_GZKmADvR9MSGyAqsKGydEFgBEcKKwcmpvAd6Hevm88HQ at mail.gmail.com>
>> Content-Type: text/plain; charset="iso-8859-1"
>> There is probably a better way of doing this, but if you are talking
> about a
>> shapefile, you can simply open the DBF file in OpenOffice or
> LibreOffice,
>> and Print it.
>> Alexandre Neto
>> On Wed, Aug 31, 2011 at 5:16 PM, Andrew Novak <novak.andj at gmail.com>
> Message: 2
> Date: Thu, 1 Sep 2011 10:18:08 +1200
> Subject: Re: [Qgis-user] Profile Tool
> Cc: garcia.silva at gmail.com
> Message-ID:
> 	<AAFD34025E073F47B5F892A97BAFFCAA5D0D94 at aklserver02.Synergine.local>
> Hi guys,
> You can manually extract the files from the shapely installer (using
> e.g. Izarc or 7zip, or possibly just by renaming it as .zip or
> something), and put them in the right places.
> You need to put the shapely folder (from inside PURELIB) in e.g.
> C:\OSGeo4W\apps\Python25\Lib\site-packages\, and the geos.dll and
> libgeos-3-2-2.dll in I think C:\OSGeo4W\bin, although instead of
> installing those I seem to have got it working by editing
> C:\OSGeo4W\apps\Python25\Lib\site-packages\shapely\geos.py to use the
> lib from OSGeo4W instead (C:\OSGeo4W\bin\geos_c.dll).
> For the record, there is also an open ticket (with a suggested script)
> for registering the OSGeo4W Python with Windows, so that python
> package
> installers can find it: http://trac.osgeo.org/osgeo4w/ticket/114
> Regarding the profile tool plugin, Micha, it definitely runs on
> Windows.
> But on one of my machines I also got that error message about having
> no
> Qwt5.
> If I remember correctly, the problem was something like this: it
> requires the latest Qwt5 (or PyQwt5) in the OSGeo4W repository, but
> this
> machine only had an older version installed, and the OSGeo4W installer
> was not showing the latest version for some reason.
> I believe to fix it I uninstalled PyQwt5 and Qwt5, then reinstalled
> them.
> Alister
>> Date: Wed, 31 Aug 2011 10:35:44 -0500
>> From: David Fawcett <david.fawcett at gmail.com>
>> To: Ricardo Filipe Soares Garcia da <ricardo.garcia.silva at gmail.com>
>> Message-ID:
> <CAF7K3b-RvCLBswiq807pE-a9+_pCB2LUwu+X+eQmK0=Pekg4jw at mail.gmail.com>
>> Content-Type: text/plain; charset=ISO-8859-1
>> There is a windows installer for Shapely.
>> http://pypi.python.org/pypi/Shapely#downloads
>> The problem that I ran into was that the installer defaults to the
>> Python install listed in the Registry.  For me, (and probably most
>> people), that is not the Python instance installed by OSGEO4W.  At
>> least last time that I attempted the install, there was no way to
>> tell
>> the Shapely installer to use a different Python instance.
>> David.
>> On Wed, Aug 31, 2011 at 8:15 AM, Ricardo Filipe Soares Garcia da
>> <ricardo.garcia.silva at gmail.com> wrote:
>>> Hi Micha
>>> Concerning the 'Profile from Line' plugin, I've opened a ticket some
>>> months ago at OSGEO4W's bugtracker asking for packaging of a more
>>> recent version of the Shapely package but haven't had a reply. I
> guess
>>> they haven't gotten around to do it yet.
>>> However, I believe there must be a way of installing Shapely (and
>>> other Python packages) separately and then make them available
> inside
>>> OSGEO4W. Unfortunately I have never tried to do so, as I never had
>>> such a need. Maybe others can help out.
>>> Best regards
>>> 2011/8/31 Micha Silver <micha at arava.co.il>:
>>>> I'm trying to install the Profile Tool plugin on an OSGeo4W setup.
> The
>>>> plugin won't install saying it needs Qwt5, but that library should
> be
>>>> install by the OSGeo4W-setup.
>>>> WHat am I missing?
>>>> BTW, the "Profile from Line" plugin need s Shapely 1.2 and the
> OSGeo4W has
>>>> shapely 1.0. So is there no profile tool for Win users?
>>>> Thanks,
>>>> Micha
> Message: 3
> Date: Thu, 1 Sep 2011 11:18:13 +1200
> Subject: RE: [Qgis-user] How Do I Set Field Calculator Units For Area
> Message-ID:
> 	<AAFD34025E073F47B5F892A97BAFFCAA5D0DA6 at aklserver02.Synergine.local>
> Hi there,
> I *think* the area calculations are always in the unit for the layer's
> CRS.  So you could either:
> - find out what this unit is, and convert the areas to square feet by
> multiplying by the correct factor, or
> - convert the layer to a CRS which uses square feet.
> N.B. there is a feature request to enable coordinate conversion in the
> field calculator (although I didn't mention that it would be useful
> also
> for area and length calculations).  See http://hub.qgis.org/issues/
> 4078
> Alister
>> Date: Wed, 31 Aug 2011 11:18:32 -0500
>> From: Andrew Novak <novak.andj at gmail.com>
>> Subject: [Qgis-user] How Do I Set Field Calculator Units For Area
>> 	Calcs?
>> To: qgis-user at lists.osgeo.org
>> Message-ID:
> <CAO0Lqnon=aJMKGUb=BPacqxgn+PGn4G2vpe8sn=epxyT+pKtbw at mail.gmail.com>
>> The area calculations from my field calculator are in an unknown
>> unit.
> I
>> simply want my units to be square feet. How can I set my units in the
> field
>> calculator??
> End of Qgis-user Digest, Vol 67, Issue 1
