[Qgis-user] Fill Style
Paul Lens paul.lens at base.be
Fri Dec 9 08:17:04 PST 2011
Thanks a lot for all theses explanations.
Paul
On 8/12/2011 22:31, Andreas Neumann wrote:
> Hi Paul,
> The pattern editors (line patteren fills and raster pattern fills) are
> only in trunk, not in 1.7.2
> You need the trunk version to use this new feature.
> Alternatively you can use SVG fill patterns where you can easily also
> simulate line pattern fills, be specifying an SVG file with parallel
> vertical or horizontal lines and then adapt width/height and rotation.
> This also works with 1.7.2
> You can use Inkscape to draw the pattern (it can only be one or two
> horizontal or vertical lines) and then save it where all the other SVG
> files reside.
> Hope this helps,
> Andreas
> On 12/08/2011 07:38 PM, Paeul Lens wrote:
>> Hi Marco,
>> This 'line pattern fill' pattern should be a wonderful feature; but I do
>> not find it.
>> I didn't find it either in the QGIS Manual. This is the description
>> found in page 50:
>>               Symbol layer type options for polygon layers
>>                  – SimpleFill: Color, Fill style, Border color, Border
>> style, Border width
>> Where am I missing something?
>> Using 1.7.2. on windows Vista sp2.
>>      Paul
>> On 7/12/2011 14:37, Marco Hugentobler wrote:
>>> Hi Bernhard
>>> If you go to new symboloy and select symbol layer type 'line pattern
>>> fill', you could e.g. set 'distance' to 2 (mm or map units) and width
>>> to 1.
>>> Regards,
>>> Marco
>>> On 07.12.2011 14:26, bernhard.stroebl at jena.de wrote:
>>>> Dear all,
>>>> I need a fill style with a diagonal pattern where the color and the
>>>> gap both have the same width.
>>>> Any hints how to achieve this?
>>>> Bernhard
>>>> ________ Information from NOD32 ________
>>>> This message was checked by NOD32 Antivirus System for Linux Mail
>>>> Server.
>>>> http://www.nod32.com
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
