[Qgis-user] Python modules (dependencies?)
Giovanni Manghi giovanni.manghi at gmail.com
Thu Dec 15 07:20:13 PST 2011
can you paste here the python error messages you are getting using the
plugin?
cheers
-- Giovanni --
On Thu, 2011-12-15 at 10:03 -0500, Thomas J. Boyd wrote:
> Dear List users,
> I have been unable to find an answer to this via searching, so here
> goes: I use QGIS v.1.7.2 (now 1.7.3) windows binaries. I want to use the
> contour plugin. According the docs, it requires shapely, numpy, and
> matplotlib. The contour python files are loaded into my documents
> directory in sub /.qgis/python/plugins/contour.
> After installing either the 2.5 or 2.7 python binaries and libraries
> (including numpy, shapely and matplotlib), I still get errors trying to
> use contour. I did default install(s) for python (in the "Program files"
> directory). I tried copying over the numpy, shapely and matplotlib
> python files to my .qgis/python/plugins folder but get errors loading
> QGIS (for either 2.5 32-bit or 2.7 64-bit python installs). I can run
> "other" python scripts in a command window (so the python interpreter is
> "registered" I think). I can run numpy, shapely and matplotlib functions
> in IDLE without issue.
> Has anyone had experience running contour plugin on a windows machine?
> Any install tips? I am using Win7 64-bit. Thanks in advance for any
> assistance.
> Tom
