[Qgis-user] Python modules (dependencies?)
Alexander Bruy alexander.bruy at gmail.com
Thu Dec 15 07:23:34 PST 2011
Hi Thomas,
how you install QGIS: via OSGeo4W or using standalone installer?
If you use OSGeo4W you can get all dependencies. The standalone
installer includes some additional deps, but if you need to add another
packages — install them into Python bundled with QGIS not into
system wide Python
2011/12/15 Thomas J. Boyd <thomas.boyd at nrl.navy.mil>:
> Dear List users,
> I have been unable to find an answer to this via searching, so here goes: I
> use QGIS v.1.7.2 (now 1.7.3) windows binaries. I want to use the contour
> plugin. According the docs, it requires shapely, numpy, and matplotlib. The
> contour python files are loaded into my documents directory in sub
> /.qgis/python/plugins/contour.
> After installing either the 2.5 or 2.7 python binaries and libraries
> (including numpy, shapely and matplotlib), I still get errors trying to use
> contour. I did default install(s) for python (in the "Program files"
> directory). I tried copying over the numpy, shapely and matplotlib python
> files to my .qgis/python/plugins folder but get errors loading QGIS (for
> either 2.5 32-bit or 2.7 64-bit python installs). I can run "other" python
> scripts in a command window (so the python interpreter is "registered" I
> think). I can run numpy, shapely and matplotlib functions in IDLE without
> issue.
> Has anyone had experience running contour plugin on a windows machine? Any
> install tips? I am using Win7 64-bit. Thanks in advance for any assistance.
Alexander Bruy
