[Qgis-user] Re: new xytools plugin: now open and save simple Excel files
Arif Arham arhamilis at gmail.com
Sat Dec 17 15:17:20 PST 2011
It works now!
Thanks, Richard.
-Arif
On Sun, Dec 18, 2011 at 12:49 AM, Richard Duivenvoorde <richard at duif.net>wrote:
> The next version will not show you this python error anymore, but a
> message that you have to install the python libs xlrd and xlwr...
> On Ubuntu
> just do
> sudo apt-get install xlwt xlrd
> this will install the nessecary python libraries which are needed to do
> the excel reading and writing
> (and you are invited to read the help from the xytools context menu :-) )
> Regards,
> Richard
> On 2011-12-17 17:55, Arif Arham wrote:
> > I work on Ubuntu 11.10, QGIS 1.7.3
> > ----start-------
> > An error has occured while executing Python code:
> > Traceback (most recent call last):
> >   File "/home/areev/.qgis/python/plugins/xytools/xytools.py", line 188,
> > in excelSave
> >     from providers import excel
> >   File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 283, in
> > _import
> >     mod = _builtin_import(name, globals, locals, fromlist, level)
> >   File "/home/areev/.qgis/python/plugins/xytools/providers/excel.py",
> > line 1, in
> >     import xlwt
> > _import
> > ImportError: No module named xlwt
> > Python version:
> > 2.7.2+ (default, Oct  4 2011, 20:29:37)
> > [GCC 4.6.1]
> > QGIS version:
> > 1.7.3-Wroclaw Wroclaw, exported
> > Python path: ['/usr/share/qgis/python', '/home/areev/.qgis/python',
> > '/home/areev/.qgis/python/plugins', '/usr/share/qgis/python/plugins',
> > '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2',
> > '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
> > '/usr/lib/python2.7/lib-dynload',
> > '/usr/local/lib/python2.7/dist-packages',
> > '/usr/lib/python2.7/dist-packages',
> > '/usr/lib/python2.7/dist-packages/PIL',
> > '/usr/lib/python2.7/dist-packages/gst-0.10',
> > '/usr/lib/python2.7/dist-packages/gtk-2.0',
> > '/usr/lib/pymodules/python2.7',
> > '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
> > '/usr/lib/python2.7/dist-packages/ubuntuone-client',
> > '/usr/lib/python2.7/dist-packages/ubuntuone-control-panel',
> > '/usr/lib/python2.7/dist-packages/ubuntuone-couch',
> > '/usr/lib/python2.7/dist-packages/ubuntuone-installer',
> > '/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol',
> > '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
> > '/home/areev/.qgis/python/plugins/openlayersov/logic',
> > '/home/areev/.qgis/python/plugins/openlayersov/gui',
> > '/usr/share/qgis/python/plugins/fTools/tools']
> > ------end-----------
> > On Sat, Dec 17, 2011 at 3:14 PM, Richard Duivenvoorde
> > <rdmailings at duif.net <mailto:rdmailings at duif.net>> wrote:
> >     On 2011-12-17 00:57, Arif Arham wrote:
> >     > I got a problem when executing "Save attribute table as Excel
> file".
> >     > In fact, several plugins end with this kind of errors. Is it
> python's
> >     > bug or plugin's bug?
> >     can you give more info? In this mail I cannot see the actual message
> >     also not here:
> http://osgeo-org.1803224.n2.nabble.com/new-xytools-plugin-now-open-and-save-simple-Excel-files-td7098439.html#a7101831
> >     You can sent me a screendump or copy the full message from the error
> >     window.
> >     Otherwise, let me know which OS and Qgis version you use, and/or
> sent me
> >     the data that is throwing the error.
> >     Regards,
> >     Richard
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111218/bd2078c5/attachment.html>
