[Qgis-user] Re: [Qgis-developer] JOIN error
Agustin Lobo alobolistas at gmail.com
Fri Dec 23 00:54:05 PST 2011
Hi!
I circumvented the problem using the older tool in fTools
Vector/Data Management Tools/Join
(Carson is going to restore this option to fTools until we make
sure Properties/Joints is always working)
and also using R (both results are identical).
Agus
2011/12/21 Ramon Andiñach <custard at westnet.com.au>:
> On 19/12/2011, at 03:15 , Agustin Lobo wrote:
>> I use Properties/JOINS to join a dbf table to a vector layer
>> (fields ISO and ISO3 respectively). The Join works, but
>> I get the following error when I  try to save the vector layer as
>> a new shapefile:
>> Export to vector file failed.
>> Error: Feature write errors:
>> Invalid variant type for field X[11]: received void with type
>> (many times repeated)
>> Only 24 of 246 features written.
>> The new layer is actually written (despite claiming "Export to vector
>> failed") but only those countries with data in the dbf are available
> Hi Agus,
> I'm curious where you were trying to get to with this join?
> (I know it's not working the way you would like, but thinking short term about a work around).
> If you're heading for a map showing countries with that owl species, then you could get the same result (intentionally, with out the errors) using a sort and save selection, and then overlay the new layer on the world map.
> More layers, similar result.
> But it does depend what you were trying to do.
> -ramon._______________________________________________
> Qgis-user mailing list
