[Qgis-user] Hi everybody
Gerardo Jimenez gejst5 at hotmail.com
Tue Dec 27 09:55:12 PST 2011
If you have a shape file it should have also a *.prj file. This file defines the projection of your layer. By default, Qgis assumes that your data is a lat lon wgs84 and coordinate units degrees. If you have your *.prj file try this first
Open QGis, load the layer select it and choose set project crs from layer
If that does not do the trick try opening the prj file in a text editor and try to identify your CRS (Coordinate Reference System). Then, in Qgis, after loading your layer, Go to layer properties/General choose the specify button and look for your crs in the "Projected Coordinate Systems" section. Do the same at Settings/Project Properties/CRS Tab.
Hope it helps
Gerardo Jiménez Delgado
Instituto de Investigaciones Antropológicas
Universidad Nacional Autónoma de México
Ciudad Universitaria s/n
Coyoacan 04510
Mexico City
Mexico
56 22 95 16
Date: Tue, 27 Dec 2011 15:09:00 +0000
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Hi everybody
Hi, I'm Giacomo Fontanellin from Florence, Italy.I'm a PhD for University of Basilicata, I work on remote sensing of environment.I'm quite new with QGis, buti I like it, cause it's very easy to use and user-friendly. This is my problem: I've got many shape file in a project, each of those with different projections, but I still can visualize the polygons in the right position. The spatial extension of the files is almost the same and is defined in meters: example: xMin, yMin 1714882.75,4845790.12 : xMax,yMax 1735233.69,4861856.86.
Unfortunally I've got a layer with the spatial extension defined in degrees: xMin, yMin 10.94,43.7388 : xMax,yMax 11.7543,43.9773, and I can't visualize it in the correct location. How can I change the extension of the files from degrees to meters and viceversa? Thank you very much and sorry for my english
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111227/a5188be3/attachment.html>
