[Qgis-user] Add new template to the composer
Giovanni Manghi
giovanni.manghi at faunalia.pt
Wed Dec 28 08:36:41 PST 2011
Hi Yves,
are you speaking about the easyprint plugin?
If yes then remember that is a 3rd party plugin, so no surprise that it
comes with a set of templates that are not for general use.
You may want to have a look into the plugin folder, inside .qgis, for
the layouts.xml file, where you can configure your own layouts.
Much better would be supporting the work to integrate the layouts
created with the QGIS composer into the easy print plugin (or to make
the plugin read the layouts created with the standard composer).
cheers
-- Giovanni --
On Wed, 2011-12-28 at 16:52 +0100, Yves Jacolin wrote:
> Hello,
> When I open the composer manager, there is a dropdown list to choose the
> template for the new composer. There is always one item and I can't see how to
> change this (add a new template for instance).
> Furthermore, easyPrint use a specific template that don't fit for everybody need
> and therefore this plugins is not so usefull.
> Do you know any way to create template for the composer?
> Thanks,
> Y.
> Qgis-user mailing list
