[Qgis-user] Add new template to the composer
Yves Jacolin yjacolin at free.fr
Wed Dec 28 08:54:59 PST 2011
Hello,
Not really. It seems that user can create new template but I can't find the
correct way. The documentation don't speak much about this feature so I am
asking to other.
What is the correct way to createa new template in the composer manager? Do we
need to write xml file? Is it the same template as the easyprint use?
Thanks,
Y.
Le mercredi 28 décembre 2011 17:36:41, Giovanni Manghi a écrit :
> Hi Yves,
> are you speaking about the easyprint plugin?
> If yes then remember that is a 3rd party plugin, so no surprise that it
> comes with a set of templates that are not for general use.
> You may want to have a look into the plugin folder, inside .qgis, for
> the layouts.xml file, where you can configure your own layouts.
> Much better would be supporting the work to integrate the layouts
> created with the QGIS composer into the easy print plugin (or to make
> the plugin read the layouts created with the standard composer).
> cheers
> -- Giovanni --
> On Wed, 2011-12-28 at 16:52 +0100, Yves Jacolin wrote:
> > Hello,
> > When I open the composer manager, there is a dropdown list to choose the
> > template for the new composer. There is always one item and I can't see
> > how to change this (add a new template for instance).
> > Furthermore, easyPrint use a specific template that don't fit for
> > everybody need and therefore this plugins is not so usefull.
> > Do you know any way to create template for the composer?
> > Thanks,
> > Y.
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
