[Qgis-user] Re: [Qgis-developer] JOIN error
Ramon AndiƱach custard at westnet.com.au
Thu Dec 29 18:13:34 PST 2011
I'm a bit like Agus, and am not in a position to compile to test properly.
But I can confirm it is working in the osgeo compilation of 1.9 (master).
-ramon.
On 23/12/2011, at 18:40 , Agustin Lobo wrote:
> Alexander,
> In order to check on ubuntu, I would need to either compile (which I
> do not know how to do)
> or install the nightly build (which would overwrite my current
> installation), am I wrong?
Mostly no, but it does require compilation of various add on bits (e.g. if your not in a situation to avoid ecw files). The .deb nightly files, as was pointed out to me are mostly about making sure qgis itself works, and anything else is a bonus.
> Also, this would not be a solution for windows users relying on the
> "stable" 1.7.3
> A good thing of having back this tool in fTools is that improved
> versions can be easily installed as an
> updated plugin. I think that being the JOIN a fundamental operation,
> it should be kept it in fTools
> until we are positive that Properties/JOIN always work, which will not
> happen until users exhaustively test
> it from an standard binary distribution.
> Agus
> 2011/12/23 Alexander Bruy <alexander.bruy at gmail.com>:
>> Hi,
>> this fixed yesterday in 7f0dc3c25403 and backported to
>> 1.7 and 1.8 branches. Please check.
>> So we don't need to restore Join in fTools
>> Alexander Bruy
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
