[Qgis-user] Re: [Qgis-developer] JOIN error
Agustin Lobo
alobolistas at gmail.com
Fri Dec 30 04:32:14 PST 2011
Ramon,
by "the osgeo compilation of 1.9 (master)" do you mean osgeo4w ?
Or is there an alternative site for binary distributions (other than
http://hub.qgis.org/projects/quantum-gis/wiki/Download ) ?
(I do not use osgeo4w, as I think that it is as or even more complex
than having a real linux system
and you do not get all the rest of advantages included with a linux
distribution.)
Agus
2011/12/30 Ramon AndiƱach <custard at westnet.com.au>:
> Hi,
> I'm a bit like Agus, and am not in a position to compile to test properly.
> But I can confirm it is working in the osgeo compilation of 1.9 (master).
> -ramon.
> On 23/12/2011, at 18:40 , Agustin Lobo wrote:
>> Alexander,
>> In order to check on ubuntu, I would need to either compile (which I
>> do not know how to do)
>> or install the nightly build (which would overwrite my current
>> installation), am I wrong?
> Mostly no, but it does require compilation of various add on bits (e.g. if your not in a situation to avoid ecw files). The .deb nightly files, as was pointed out to me are mostly about making sure qgis itself works, and anything else is a bonus.
>> Also, this would not be a solution for windows users relying on the
>> "stable" 1.7.3
>> A good thing of having back this tool in fTools is that improved
>> versions can be easily installed as an
>> updated plugin. I think that being the JOIN a fundamental operation,
>> it should be kept it in fTools
>> until we are positive that Properties/JOIN always work, which will not
>> happen until users exhaustively test
>> it from an standard binary distribution.
>> Agus
>> 2011/12/23 Alexander Bruy <alexander.bruy at gmail.com>:
>>> Hi,
>>> this fixed yesterday in 7f0dc3c25403 and backported to
>>> 1.7 and 1.8 branches. Please check.
>>> So we don't need to restore Join in fTools
>>> Alexander Bruy
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
