[Qgis-user] GPSTools plugin - not downloading from GPS
Bernhard.Stroebl at jena.de Bernhard.Stroebl at jena.de
Thu Jun 23 05:44:06 PDT 2011
had the same message today when trying to download tracks from my garmin
device via usb. It turned out to be the usb-Driver has not been
installed on this machine. Installing it solved the problem. As you say
gpsbabel itself works, maybe you misconfigured the device or the port.
Just a guess, though.
all the best
Bernhard
Am 23.06.2011 14:18, schrieb Micha Silver:
> Trying 1.7 on Windows. It seems that the GPSTools plugin still does not
> successfully  download from a GPS instrument. I still (it was the same with 1.6)
> get an error such as:
> "The layer bike.gpx?type=waypoint is not a valid layer and can not be added to
> the map"
> I tried both the OSGeo4W setup and the standalone installer. Same result.
> Note that using the GPSBabelFE GUI works fine, as does gpsbabel from the command
> line. Using either of these methods, the resulting gpx file can be loaded with
> the GPSTools plugin. But the "Download from GPS" option within the GPS Tools
> plugin does not seem to work.
> Anyone else seen this?
> Thanks,
> Micha
> Hevra Logo
> Micha Silver
> Arava Development Co
> 052-3665918
> http://www.surfaces.co.il
> *________ Information from NOD32 ________*
> This message was checked by NOD32 Antivirus System for Linux Mail Server.
> http://www.nod32.com
> Qgis-user mailing list
Dipl.-Geogr. Bernhard Ströbl
Anwendungsbetreuer GIS
Kommunale Immobilien Jena
  - Datenverarbeitung -
mailto:Bernhard.Stroebl at jena.de
http://kij.jena.de/
