[Qgis-user] GPSTools plugin - not downloading from GPS
Micha Silver
micha at arava.co.il
Thu Jun 23 12:14:52 PDT 2011
On 23/06/2011 15:44, Bernhard.Stroebl at jena.de wrote:
> Hi,
> had the same message today when trying to download tracks from my
> garmin device via usb. It turned out to be the usb-Driver has not been
> installed on this machine. Installing it solved the problem. As you
> say gpsbabel itself works, maybe you misconfigured the device or the
> port. Just a guess, though.
Thanks,
Just to be sure I reinstalled the Garmin driver for windows. No
difference, I still get the error (see attached screen shot).
And running gpsbabel from the command line, or thru the GPSBabel GUI
works fine.
I wonder if this problem is a continuation of this [1] trac issue that
was reopened recently?
[1] https://trac.osgeo.org/qgis/ticket/1170
Regards,
Micha
> all the best
> Bernhard
> Am 23.06.2011 14:18, schrieb Micha Silver:
>> Trying 1.7 on Windows. It seems that the GPSTools plugin still does not
>> successfully download from a GPS instrument. I still (it was the
>> same with 1.6)
>> get an error such as:
>> "The layer bike.gpx?type=waypoint is not a valid layer and can not be
>> added to
>> the map"
>> I tried both the OSGeo4W setup and the standalone installer. Same
>> result.
>> Note that using the GPSBabelFE GUI works fine, as does gpsbabel from
>> the command
>> line. Using either of these methods, the resulting gpx file can be
>> loaded with
>> the GPSTools plugin. But the "Download from GPS" option within the
>> GPS Tools
>> plugin does not seem to work.
>> Anyone else seen this?
>> Thanks,
>> Micha
>> Hevra Logo
>> Micha Silver
>> Arava Development Co
>> 052-3665918
>> http://www.surfaces.co.il
>> *________ Information from NOD32 ________*
>> This message was checked by NOD32 Antivirus System for Linux Mail
>> Server.
>> http://www.nod32.com
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Server.
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110623/97f1d2a9/attachment.gif>
