[Qgis-user] ftools error in the recent update
benoit-3 at bc-consult.com
Tue Mar 1 02:11:30 PST 2011
Hi Carson,
Thanks for the quick update.
Just to let you know that the about dialog displays version 0.5.10
instead of 0.6.1
Regards,
Benoit
On Tue, 1 Mar 2011 09:17:02 +0000, Carson Farmer
<carson.farmer at gmail.com> wrote:
> I was not aware of this problem. Could you please update to the most
> recent version of fTools via the Python repositories, and then test
> and confirm that this is still an issue. If it is, could you please
> forward the error message that you are getting.
> Regards,
> Carson
> On Tue, Mar 1, 2011 at 9:15 AM, Carson Farmer
>> This is likely due to an update I made last night. Apologies for
>> that!
>> I have uploaded a new version which should not have these problems.
>> Please test and confirm that it is fixed.
>> Regards,
>> Carson
>> On Tue, Mar 1, 2011 at 3:26 AM, maning sambale
>> <emmanuel.sambale at gmail.com> wrote:
>>> I get this error:
>>> Couldn't load plugin fTools due an error when calling its
>>> classFactory() method
>>> Traceback (most recent call last):
>>> File
>>> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py",
>>> line 138, in startPlugin
>>> plugins[packageName] = package.classFactory(iface)
>>> File "/Users/maning/.qgis/python/plugins/fTools/__init__.py", line
>>> 36, in classFactory
>>> from fTools import fToolsPlugin
>>> File
>>> line 279, in _import
>>> mod = _builtin_import(name, globals, locals, fromlist, level)
>>> File "/Users/maning/.qgis/python/plugins/fTools/fTools.py", line
>>> 37, in
>>> import resources_rc
>>> File
>>> ImportError: No module named resources_rc
>>> Python version:
>>> 2.5.1 (r251:54863, Sep 1 2010, 22:03:14)
>>> [GCC 4.0.1 (Apple Inc. build 5465)]
>>> QGIS version:
>>> 1.6.0-Copiapo Copiapo, exported
>>> Python path:
>>> ['/Applications/Qgis.app/Contents/MacOS/../Resources/python',
>>> '/Users/maning/.qgis/python', '/Users/maning/.qgis/python/plugins',
>>> '/Applications/Qgis.app/Contents/MacOS/../Resources/python/plugins',
>>> '/Library/Frameworks/SQLite3.framework/Versions/3/Python',
>>> '/Library/Python/2.5/site-packages/numpy-override',
>>> '/Library/Frameworks/GDAL.framework/Versions/1.7/Python/site-packages',
>>> '/Library/Python/2.5/site-packages/GDAL-1.5.2-py2.5-macosx-10.5-i386.egg',
>>> '/Library/Python/2.5/site-packages/setuptools-0.6c8-py2.5.egg',
>>> '/Library/Python/2.5/site-packages/python_dateutil-1.4-py2.5.egg',
>>> '/Library/Python/2.5/site-packages/PyYAML-3.05-py2.5.egg',
>>> '/Library/Python/2.5/site-packages/gantt-0.1-py2.5.egg',
>>> '/Library/Python/2.5/site-packages/numpy-1.1.1-py2.5-macosx-10.5-i386.egg',
>>> '/Library/Python/2.5/site-packages/pycairo-1.6.4-py2.5-macosx-10.5-i386.egg',
>>> '/Library/Python/2.5/site-packages/Shapely-1.0.6-py2.5.egg',
>>> '/Library/Python/2.5/site-packages/pyparsing-1.5.2-py2.5.egg',
>>> '/Library/Python/2.5/site-packages/rpy2-2.0.8-py2.5-macosx-10.5-i386.egg',
>>> '/Library/Python/2.5/site-packages/PIL-1.1.7-py2.5-macosx-10.5-i386.egg',
>>> '/Library/Python/2.5/site-packages/docutils-0.6-py2.5.egg',
>>> '/Library/Python/2.5/site-packages/pyproj-1.8.8-py2.5-macosx-10.5-i386.egg',
>>> '/Library/Frameworks/cairo.framework/Versions/1/Python',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python25.zip',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-darwin',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-mac',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-mac/lib-scriptpackages',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.5/Extras/lib/python',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/lib-tk',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/lib-dynload',
>>> '/Library/Python/2.5/site-packages',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.5/Extras/lib/python/PyObjC',
>>> '/Users/maning/.qgis/python/plugins/cadtools/tools',
>>> '~/.qgis/python']
>>> cheers,
>>> maning
>>> "Freedom is still the most radical idea of all" -N.Branden
>>> wiki: http://esambale.wikispaces.com/
>>> blog: http://epsg4253.wordpress.com/
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Carson J. Q. Farmer
>> ISSP Doctoral Fellow
>> National Centre for Geocomputation
>> National University of Ireland, Maynooth,
>> http://www.carsonfarmer.com/
