[Qgis-user] ftools error in the recent update
telesforo innocenti
innocenti.sr at gmail.com
Tue Mar 1 02:35:50 PST 2011
YESSS, TUTTO OK!!!
2011/3/1 <benoit-3 at bc-consult.com>
> Hi Carson,
> Thanks for the quick update.
> Just to let you know that the about dialog displays version 0.5.10 instead
> of 0.6.1
> Regards,
> Benoit
> On Tue, 1 Mar 2011 09:17:02 +0000, Carson Farmer <carson.farmer at gmail.com>
> wrote:
>> I was not aware of this problem. Could you please update to the most
>> recent version of fTools via the Python repositories, and then test
>> and confirm that this is still an issue. If it is, could you please
>> forward the error message that you are getting.
>> Regards,
>> Carson
>> On Tue, Mar 1, 2011 at 9:15 AM, Carson Farmer
>> <carson.farmer at gmail.com> wrote:
>>> This is likely due to an update I made last night. Apologies for that!
>>> I have uploaded a new version which should not have these problems.
>>> Please test and confirm that it is fixed.
>>> Regards,
>>> Carson
>>> On Tue, Mar 1, 2011 at 3:26 AM, maning sambale
>>> <emmanuel.sambale at gmail.com> wrote:
>>>> I get this error:
>>>> Couldn't load plugin fTools due an error when calling its classFactory()
>>>> method
>>>> Traceback (most recent call last):
>>>> File
>>>> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py",
>>>> line 138, in startPlugin
>>>> plugins[packageName] = package.classFactory(iface)
>>>> File "/Users/maning/.qgis/python/plugins/fTools/__init__.py", line
>>>> 36, in classFactory
>>>> from fTools import fToolsPlugin
>>>> File
>>>> line 279, in _import
>>>> mod = _builtin_import(name, globals, locals, fromlist, level)
>>>> File "/Users/maning/.qgis/python/plugins/fTools/fTools.py", line 37, in
>>>> import resources_rc
>>>> File
>>>> ImportError: No module named resources_rc
>>>> Python version:
>>>> 2.5.1 (r251:54863, Sep 1 2010, 22:03:14)
>>>> [GCC 4.0.1 (Apple Inc. build 5465)]
>>>> QGIS version:
>>>> 1.6.0-Copiapo Copiapo, exported
>>>> Python path:
>>>> ['/Applications/Qgis.app/Contents/MacOS/../Resources/python',
>>>> '/Users/maning/.qgis/python', '/Users/maning/.qgis/python/plugins',
>>>> '/Applications/Qgis.app/Contents/MacOS/../Resources/python/plugins',
>>>> '/Library/Frameworks/SQLite3.framework/Versions/3/Python',
>>>> '/Library/Python/2.5/site-packages/numpy-override',
>>>> '/Library/Frameworks/GDAL.framework/Versions/1.7/Python/site-packages',
>>>> '/Library/Python/2.5/site-packages/GDAL-1.5.2-py2.5-macosx-10.5-i386.egg',
>>>> '/Library/Python/2.5/site-packages/setuptools-0.6c8-py2.5.egg',
>>>> '/Library/Python/2.5/site-packages/python_dateutil-1.4-py2.5.egg',
>>>> '/Library/Python/2.5/site-packages/PyYAML-3.05-py2.5.egg',
>>>> '/Library/Python/2.5/site-packages/gantt-0.1-py2.5.egg',
>>>> '/Library/Python/2.5/site-packages/numpy-1.1.1-py2.5-macosx-10.5-i386.egg',
>>>> '/Library/Python/2.5/site-packages/pycairo-1.6.4-py2.5-macosx-10.5-i386.egg',
>>>> '/Library/Python/2.5/site-packages/Shapely-1.0.6-py2.5.egg',
>>>> '/Library/Python/2.5/site-packages/pyparsing-1.5.2-py2.5.egg',
>>>> '/Library/Python/2.5/site-packages/rpy2-2.0.8-py2.5-macosx-10.5-i386.egg',
>>>> '/Library/Python/2.5/site-packages/PIL-1.1.7-py2.5-macosx-10.5-i386.egg',
>>>> '/Library/Python/2.5/site-packages/docutils-0.6-py2.5.egg',
>>>> '/Library/Python/2.5/site-packages/pyproj-1.8.8-py2.5-macosx-10.5-i386.egg',
>>>> '/Library/Frameworks/cairo.framework/Versions/1/Python',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python25.zip',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-darwin',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-mac',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-mac/lib-scriptpackages',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.5/Extras/lib/python',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/lib-tk',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/lib-dynload',
>>>> '/Library/Python/2.5/site-packages',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.5/Extras/lib/python/PyObjC',
>>>> '/Users/maning/.qgis/python/plugins/cadtools/tools', '~/.qgis/python']
>>>> cheers,
>>>> maning
>>>> "Freedom is still the most radical idea of all" -N.Branden
>>>> wiki: http://esambale.wikispaces.com/
>>>> blog: http://epsg4253.wordpress.com/
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Carson J. Q. Farmer
>>> ISSP Doctoral Fellow
>>> National Centre for Geocomputation
>>> National University of Ireland, Maynooth,
>>> http://www.carsonfarmer.com/
Telesforo Innocenti
+39.329.1825000
Skype: innocenti.sr
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110301/f7802769/attachment.html>
