[Qgis-user] PostGIS viewer -PgAdmin plugin
Germán Carrillo
carrillo.german at gmail.com
Sat Mar 5 18:59:28 PST 2011
Hi all,
I have added some functionalities to the plugin [1], now it:
* Has PostGIS rasters (WKTRaster) support (Based on WKTRaster QGIS plugin.)
* Has a layer list widget displaying a number of layer properties.
On the other hand, the antialiasing feature has been enabled (according to
the thread opened in the dev mailing-list) and the map units detection has
been checked and fixed (thanks Ivan).
Regards,
Germán
[1]
http://geotux.tuxfamily.org/index.php?option=com_myblog&task=view&id=277&Itemid=59&lang=en
2011/2/25 Germán Carrillo <carrillo.german at gmail.com>
> Hi Ivan,
> I am going to check those 2 points, I had not checked the linear units.
> Actually, I started with the first version of your viewer and I did not
> realize the 'Layer properties' until it was too late. It makes sense to
> display some properties for a layer, so, sure!
> Regards,
> Germán
> 2011/2/25 Ivan Mincik <ivan.mincik at gmail.com>
> I have uploaded Your version to Github [1] under 'multilayer' branch.
>> Do You have any plans to recreate bottom 'Layer properties' window to
>> support multiple layers ? If this would be done, I will completely
>> turn to Your version.
>> Thanks,
>> Ivan
>> [1] - https://github.com/imincik/QgsPostGIS-Viewer/tree/multilayer
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> |\__
> (:>__)(
> Soluciones Geoinformáticas Libres
|\__
(:>__)(
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110305/3e64ba2b/attachment.html>
