Large shape files and databases. WAS: [Qgis-user] Very slow performance with large SHP files, with over 200k objects
Brad Nesom gisbradokla at live.com
Mon Mar 7 21:28:17 PST 2011
http://workshops.opengeo.org/postgis-intro/creating_db.html
very nice demo and documentation here.
On Mon, Mar 7, 2011 at 10:07 PM, Matt Boyd <mattslists at gmail.com> wrote:
> Hi Richard,
> the postgis extensions to the Postgresql database work very well in my
> experience.
> If you're using windows a google search will point you at somewhere to
> get the Postgresql server software from. Often it comes packaged with
> PgAdminIII which includes an "application stackbuilder" which will
> guide you through setting up a database with the database extensions
> enabled. Just create a template first, then use that to create the
> database you'll use.
> Once you've the database created you can create tables etc using the
> postgis manager plugin OR you can use the SPIT plugin to import your
> shapefiles. My linux install insists on creating a new GID but I just
> live with it.
> A side note, PGAdmin will let you change table and database names
> easily, I've had this break something (don't ask me what) and get odd
> error messages. Moral of this is not to be tempted to create a test
> database then do a bunch of work in it and decide to use it as your
> main database.
> This isn't quite the step by step howto but those are out there and
> hopefully this points you in the direction with some questions to ask
> of google.
> Regards
> Matt
> On Mon, Mar 7, 2011 at 9:34 PM, Ramon Andinach <custard at westnet.com.au>
> wrote:
> > On 07/03/2011, at 16:20 , <jr.morreale at enoreth.net> <
> jr.morreale at enoreth.net> wrote:
> >> On Mon, 7 Mar 2011 16:13:32 +0800, Thiru Chandran <
> tiruchirapalli at gmail.com> wrote:
> >>> Looks like QGIS is not able to handle very large SHP files. Here we are
> >>> talking about SHP files with over 200K polygons and the one that we are
> over
> >>> 500K objects.
> >>> Even to open, it takes quite a long, say  more than 40 seconds.
> >>> The issue is with search, if you do any attribute search then, its as
> good
> >>> as 5 mins to respond.
> >>> I have seen some earlier threads complaining/having the same problem..
> well
> >>> any patch / progress on this?
> >>> this is a critical requirement in one of the application and without
> the
> >>> performance, we really cant make it.
> >>> hope to see some light on this ... can we expect this in v 1.7?
> >>> Richard.
> >>> Northern Territory
> >>> Australia
> >> Even if the threading branch brings some real improvements over 1.6, you
> would get a better result by converting your dataset to a database such as
> spatialite on whihc you can set indexes and spatial idx.
> > Right. Wondered where that sort of thing became useful.
> > Are there some really basic step by half-step guides to setting up
> something like this?
> > (And I don't mean here's the protocol spec, and you can figure it out
> from there)
> > Also, are there comparisons out there of the different DBs that qgis can
> use?
> > -ramon._______________________________________________
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110307/2028ab9e/attachment.html>
