[Qgis-user] tile server with jpeg tiles
Laurent Deschaumes ldeschaumes at gmail.com
Sat Mar 12 11:57:53 PST 2011
hi all,
same behavior with the parameter tiled = true, I identified the
problem,it comes when an error occurs during the GetCapabilities
request (popup alert).
The GetCapabilities tilecache parameter "onlineresources xlink: href"
should be the same as the url WMS to work, I modified the code
tilcache and everything works fine, same behavior if I select "ignore
url in GetMap"
same behavior on all WMS eg: http://maps.opengeo.org/geowebcache/service/wms?
 I think this is a bug?
Laurent Deschaumes
2011/3/10 Frederick Löbig <frederick.loebig at live.de>:
> make sure to add "?tiled=true" to your URL and to use the getcapabilities in
> case qGIS alerts that there was an error with it. I had the same problem a
> while ago...
> Frederick Löbig
> Röderichstraße 59
> 60489 Frankfurt am Main
> E:: Frederick.Loebig at grunsnid.de
> P: +49 (0) 69 - 78 99 52 41
> M: +49 (0) 174 - 70 89 296
> Office:
> euNetworks GmbH
> Ludwig-Landmann-Straße 405
> 60486 Frankfurt am Main
> P: +49 (0) 69 - 90 554 - 532
> E: Frederick.Loebig at eunetworks.com
> S: floebig
> This email and any attachments may contain confidential and/or legally
> privileged information. If you are not the intended recipient, please delete
> the email without reading it and notify the sender.
>> Date: Thu, 10 Mar 2011 12:58:04 +0100
>> From: ldeschaumes at gmail.com
>> To: Qgis-user at lists.osgeo.org
>> CC:
>> Subject: [Qgis-user] tile server with jpeg tiles
>> hi list,
>> i have a tilecache server which serve jpeg images,
>> this tilecache works fine and i can see map/tiles with openlayers
>> but unable to see this maps with qgis,
>> what's wrong ??
>> thank's for response
>> Laurent
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
