[Qgis-user] QGIS thematic "issue"
Borys Jurgiel lists at borysjurgiel.pl
Mon Mar 14 05:40:07 PDT 2011
Dnia poniedziaƂek 14 marca 2011 o 13:22:32 Andreas Neumann napisaƂ(a):
>  Hi Yves,
>  ad 1) are you using the old or the new labeling? With the new labeling
>  (attention: the settings are not in the layer properties but in a
>  separate toolbar!) features that aren't visible due to a scale range,
>  are not labeled. So switching to the new labeling should solve your
>  problem.
I believe Yves uses the new labelling and wants to hide unwanted labels.
AFAIK there's no such possibility yet, you need to create a new text attribute
with desired labels only.
