[Qgis-user] QGIS thematic "issue"
Yves Jacolin yjacolin at free.fr
Mon Mar 14 06:45:09 PDT 2011
Le lundi 14 mars 2011 14:37:10, Andreas Neumann a écrit :
>  I tried with QGIS trunk version. Labels disappear when features are not
>  drawn due to scale ranges. So, I cannot reproduce your issue with the
>  current trunk version.
ok I will test it with the next release :)
>  Normally, you just have to enable symbol levels with the checkbox. In
>  many cases, the symbol level order proposed by QGIS will be ok. The
>  number of levels depend on the number of levels you define in the symbol
>  definition. E.g. if you added three lines on top of each other, you will
>  have symbol levels 0 to 2 (3 levels).
>  0 ... bottom layer
>  1 ... next layer
>  2 ... top layer
>  Does it help?
>  Andreas
completly, I suppose there is a bug for QGIS 1.6 because each time I enable
the symbol levels and choose my levels, when I come back to the dialog box,
symbol levels is disabled! Is it a known bug?
Thanks Andreas,
Y.
Yves Jacolin
http://yjacolin.gloobe.org
