[Qgis-user] Projection of Shapefile export
Ramon Andinach
custard at westnet.com.au
Mon Mar 21 04:51:36 PDT 2011
On 21/03/2011, at 10:21 , Brett Adams wrote:
> I thought this problem merely related to the failure of Australian projections. Projection data doesn't exist, therefore can't be exported with the shape file.
> If the points are imported as WGS84 / UTMz51S, then export the shape file, the projection file contains the relevant information. Its all good.
> So if the projection issue is fixed, shape files will then export with the required projection information.
> As far as I can see, there is no bug here. If anyone can show otherwise, we need to record the bug and create a ticket (if it doesn't exist already)
The little bit of information I had before, I just tacked on to the end of your existing ticket.
I was going to put a bit of my spare time during this week into trying to replicate Roland's solution firstly on my home linux machine and then see if I could make that approach work on windows at work.
From my recollection last time I was trying Ken's solution and a few others like just defining a CRS and couldn't quite get there.
Let you know what eventuates.
-ramon.
