[Qgis-user] ecw problems
Ramon Andinach custard at westnet.com.au
Mon Mar 21 06:36:37 PDT 2011
On 17/02/2011, at 22:27 , luca_manganelli at comune.trento.it wrote:
> qgis-user-bounces at lists.osgeo.org scritti il 17/02/2011 15.22.58
>> At the moment I've seen:
>> 1. [qgis path]/bin
>> 2. C:\windows\system32 and
>> 3. C:\windows\syswow64 (if you have a 64-bit version).
> it's sufficient to put them in 1. Test it.
Tested. It's true! That makes life simpler. Thanks.
It is also true that on a 64-bit system it will look in and use the ones in C:\windows\syswow64 first.
-ramon.
