[Qgis-user] Is DXF support dropped?
Mikhail Tchernychev misha at mail.geometrics.com
Tue Mar 22 16:06:36 PDT 2011
  I re-installed latest released version 1.6.0 and it has DXF in place.
It also shows that it is using GDAL /OGR 1.7.3
In fact ldd shows that it is linked vs.  both 1.7.0 and 1.6.0 GDAL libs (?)
Does it mean that development tree actually rolled back to GDAL 1.6.0 ?
Mikhail
On 3/22/2011 2:15 PM, Andreas Neumann wrote:
> if you use gdal 1.6 than there is no dxf support. I believe it was
> introduced in gdal 1.7. gdal 1.8 has more improvements regarding dxf,
> but QGIS does not use them yet.
> There will be dxf-related improvements for reading dxf files later
> this year in QGIS, which will allow to read layers and styling, as
> well as text and blocks. There is already a sponsor for these
> improvements. You'd have to be patient for a couple of months, though.
> Andreas
> On 3/22/11 10:08 PM, Goyo wrote:
>> 2011/3/22 Goyo<goyodiaz at gmail.com>:
>>> I can confirm this. DXF format does not appear as an option when
>>> opening or saving vector layers. Selecting the "All files" filter you
>>> can select a dxf file to open but then you get "filename.dxf is not a
>>> valid or recognized data source." ogr2ogr can convert shapefiles to
>>> dxf and ogrinfo understand dxf so the ogr driver is working. The d2s
>>> plugin is working as well.
>> Mmmmh, gdal-bin depends on libgdal1-1.7.0 while qgis depends on
>> libgdal1-1.6.0 so this could be related to ogr after all.
>> Goyo
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
