[Qgis-user] Is DXF support dropped?
Andreas Neumann a.neumann at carto.net
Tue Mar 22 14:15:11 PDT 2011
if you use gdal 1.6 than there is no dxf support. I believe it was
introduced in gdal 1.7. gdal 1.8 has more improvements regarding dxf,
but QGIS does not use them yet.
There will be dxf-related improvements for reading dxf files later this
year in QGIS, which will allow to read layers and styling, as well as
text and blocks. There is already a sponsor for these improvements.
You'd have to be patient for a couple of months, though.
Andreas
On 3/22/11 10:08 PM, Goyo wrote:
> 2011/3/22 Goyo<goyodiaz at gmail.com>:
>> I can confirm this. DXF format does not appear as an option when
>> opening or saving vector layers. Selecting the "All files" filter you
>> can select a dxf file to open but then you get "filename.dxf is not a
>> valid or recognized data source." ogr2ogr can convert shapefiles to
>> dxf and ogrinfo understand dxf so the ogr driver is working. The d2s
>> plugin is working as well.
> Mmmmh, gdal-bin depends on libgdal1-1.7.0 while qgis depends on
> libgdal1-1.6.0 so this could be related to ogr after all.
> Goyo
> Qgis-user mailing list
