[Qgis-user] Is DXF support dropped?
Goyo goyodiaz at gmail.com
Tue Mar 22 14:08:00 PDT 2011
2011/3/22 Goyo <goyodiaz at gmail.com>:
> I can confirm this. DXF format does not appear as an option when
> opening or saving vector layers. Selecting the "All files" filter you
> can select a dxf file to open but then you get "filename.dxf is not a
> valid or recognized data source." ogr2ogr can convert shapefiles to
> dxf and ogrinfo understand dxf so the ogr driver is working. The d2s
> plugin is working as well.
Mmmmh, gdal-bin depends on libgdal1-1.7.0 while qgis depends on
libgdal1-1.6.0 so this could be related to ogr after all.
Goyo
