[Qgis-user] Is DXF support dropped?
Goyo goyodiaz at gmail.com
Tue Mar 22 13:54:36 PDT 2011
2011/3/22 Mikhail Tchernychev <misha at mail.geometrics.com>:
>  I am talking about nightly build  for Linux, 1.7.0 15530M
> It use to be DXF selection in the dialog to add new vector layer. It's gone.
> The only way to bring DXF now is to use Dxf2Shp plugin.  GDAL/OGR
> does support DXF, so I don't think it's OGR problem. It is just not enabled
> on side of QGIS.
I can confirm this. DXF format does not appear as an option when
opening or saving vector layers. Selecting the "All files" filter you
can select a dxf file to open but then you get "filename.dxf is not a
valid or recognized data source." ogr2ogr can convert shapefiles to
dxf and ogrinfo understand dxf so the ogr driver is working. The d2s
plugin is working as well. BTW I just noticed that the ogr2ogr plugin
has gone.
Using r15554M binaries in Maverick.
Goyo
