[Qgis-user] Filter shape file with data in text file?
custard custard at westnet.com.au
Fri Mar 25 00:10:58 PDT 2011
----- "Alister Hood" <alister.hood at synergine.com> wrote:
> > Date: Fri, 25 Mar 2011 13:04:20 +0800
> > From: Ramon Andinach <custard at westnet.com.au>
> > Subject: [Qgis-user] Filter shape file with data in text file?
> > To: qgis-user <qgis-user at lists.osgeo.org>
> > Message-ID: <594955F2-174E-4121-A6A4-EF45C14BC967 at westnet.com.au>
> > Content-Type: text/plain; charset=us-ascii
> > Hello,
> > I'm wondering if someone could point me in the right direction for
> a
> solution
> > to this situation.
> > I have a shapefile with a large number of polygons (in this case
> mining
> > leases).
> > I have a text file that contains a list of tenements of interest.
> > I'd like to end up with a second shape file that only has the
> polygons
> shown in
> > that text file.
> > I could do it by setting up a series of filters in the General tab,
> but after
> > about the 20th TenementID = "fish" AND "TenementID = "finger" it
> gets
> a little
> > tedious.
> > The tenements are not adjacent to each other so I can't really go
> through and
> > do an area search.
> > I have tried pulling the text file in (via delimited text) and
> joining
> the
> > shapefile to it, but had errors with saving (I think because it
> thought it had
> > polygons that it was trying to put in a point file.)
> What was the error message?  The other likely one would be because
> you
> have field
> names with more than 10 characters.
> > I was not able to try it the other way around (join text to shape).
> > Does anyone have any thoughts?
> > -ramon.
> Hi Ramon,
> The delimited text plugin requires you to choose easting and northing
> columns,
> so naturally it does create a point layer.
> Try saving the .csv file as a .dbf.  You can do this with e.g.
> Openoffice.org
> or an old version of Excel.  Then you can select the .dbf file when
> you
> use
> "Vector-Join attributes".
> Alternatively, if you are running a nightly QGIS build (1.7), you
> should
> be able
> to add the .csv without geometry, by dragging and dropping it into
> the
> layer
> control, and then use the new "Joins" tab in "Layer Properties" for
> the
> polygon
> layer.
Thanks Alister,
That would answer the question in the email I've just hit send on.
Much appreciated.
-ramon.
