[Qgis-user] Announcing the Rectangles ovals digitizing plugin - not working in Ubuntu
Noli Sicad
nsicad at gmail.com
Tue Nov 8 21:38:55 PST 2011
This plugin seems not to work with Ubuntu 10.04.
Yes, I checked in QGIS manage plugin. It installed by I could see the
icon and the menu entry in QGIS.
I created a new shapefile and I toogle to edit. No icons showing in
the toolbar that resembled or look like this.
http://underdark.wordpress.com/2011/10/21/easy-rectangles-circles-and-ellipses-in-qgis/
Any instruction how to make it work in Ubuntu?
Thanks.
Noli
On 10/22/11, Pavol Kapusta <pavol.kapusta at gmail.com> wrote:
> Hello,
> i would like to introduce you the new Rectangles ovals digitizing plugin.
> This plugin is available in QGIS Contributed Repository and after
> installing creates three new objects in Digitizing toolbar: one
> multifunction button with digitizing tools, one button for rotation of
> rectangles or ovals and spinbox for changing of number of segments for
> ovals. There are 6 digitizing tools: "Rectangle by extent", "Rectangle
> from center", "Square from center", "Circle from center", "Ellipse by
> extent", "Ellipse from center". Plugin is active only when you are
> editing polygon layers. Tools, which have "from centre" in the name are
> able of snapping (after defining in Snapping Options tab of Settings)
> of the virtual center of feature.
> "Rotation tool" is functional after selection of (exactly) one
> rectangle or oval.
> After digitizing of feature, there is Feature form with possibility of
> changing default attribute values. You can deactivate this in Settings
> -> Options -> Digitizing tab -> "Suppress attributes pop-up windows
> after each created feature". Option "Reuse last entered attribute
> values" is not supported.
> I hope you will find this tools useful.
> Regards
> Pavol
> Qgis-user mailing list
