[Qgis-user] Announcing the Rectangles ovals digitizing plugin - not working in Ubuntu
Saber Razmjooei
razmjooeis at faunalia.co.uk
Wed Nov 9 02:12:26 PST 2011
Works for me under Ubuntu 10.04.
The icon should be towards the end of your Digitizing toolbar. You need
to click on it and hold to see other shapes.
Cheers
Saber
On Wed, 2011-11-09 at 16:38 +1100, Noli Sicad wrote:
> This plugin seems not to work with Ubuntu 10.04.
> Yes, I checked in QGIS manage plugin. It installed by I could see the
> icon and the menu entry in QGIS.
> I created a new shapefile and I toogle to edit. No icons showing in
> the toolbar that resembled or look like this.
> http://underdark.wordpress.com/2011/10/21/easy-rectangles-circles-and-ellipses-in-qgis/
> Any instruction how to make it work in Ubuntu?
> Thanks.
> Noli
> On 10/22/11, Pavol Kapusta <pavol.kapusta at gmail.com> wrote:
> > Hello,
> > i would like to introduce you the new Rectangles ovals digitizing plugin.
> > This plugin is available in QGIS Contributed Repository and after
> > installing creates three new objects in Digitizing toolbar: one
> > multifunction button with digitizing tools, one button for rotation of
> > rectangles or ovals and spinbox for changing of number of segments for
> > ovals. There are 6 digitizing tools: "Rectangle by extent", "Rectangle
> > from center", "Square from center", "Circle from center", "Ellipse by
> > extent", "Ellipse from center". Plugin is active only when you are
> > editing polygon layers. Tools, which have "from centre" in the name are
> > able of snapping (after defining in Snapping Options tab of Settings)
> > of the virtual center of feature.
> > "Rotation tool" is functional after selection of (exactly) one
> > rectangle or oval.
> > After digitizing of feature, there is Feature form with possibility of
> > changing default attribute values. You can deactivate this in Settings
> > -> Options -> Digitizing tab -> "Suppress attributes pop-up windows
> > after each created feature". Option "Reuse last entered attribute
> > values" is not supported.
> > I hope you will find this tools useful.
> > Regards
> > Pavol
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
