[Qgis-user] Announcing the Rectangles ovals digitizing plugin - not working in Ubuntu
Noli Sicad
nsicad at gmail.com
Wed Nov 9 02:59:15 PST 2011
OK. The inactive green rectangle is showing up again.
Installing the 0.1.2 Rectangle ovals digitizin plugin.
I also install the 0.1.6 Rectangle, Ovals, Diamonds.
What is the difference between these 2 plugins?
I installed one by one. It did not work. I installed both of the them,
it also did not work.
However, it is totally not working in Mac OS X.
Noli
On 11/9/11, Noli Sicad <nsicad at gmail.com> wrote:
> It was inactive. Nothing happened if you drag the rectangle.
> Now, I uninstalled and installed it again.
> Now, the icon inactive is gone.
> It is totally not working in Mac OS X QGIS 1.7.1.
> I will checked Ubuntu in few minutes. After I download Qt 4.7.4. It is
> quite big download 1.3G for Mac OS X.
> http://labs.qt.nokia.com/2011/11/08/qt-4-7-4-release-bundle-for-symbian-news/
> Thanks.
> On 11/9/11, Saber Razmjooei <razmjooeis at faunalia.co.uk> wrote:
>> Select a shape from the toolbar, in the canvas: click and drag.
>> Cheers
>> Saber
>> On Wed, 2011-11-09 at 21:26 +1100, Noli Sicad wrote:
>>> OK. I saw it. Thanks.
>>> I am now in Mac OS X.
>>> My laptop is triple boot :-).
>>> I toggled the Pencil icon - edit, yet I could not make to change or
>>> use the defaullt rectangle to draw.
>>> How do you use this plugin?
>>> Noli
>>> > Works for me under Ubuntu 10.04.
>>> > The icon should be towards the end of your Digitizing toolbar. You
>>> > need
>>> > to click on it and hold to see other shapes.
>>> > Cheers
>>> > Saber
>>> > On Wed, 2011-11-09 at 16:38 +1100, Noli Sicad wrote:
>>> >> This plugin seems not to work with Ubuntu 10.04.
>>> >> Yes, I checked in QGIS manage plugin. It installed by I could see the
>>> >> icon and the menu entry in QGIS.
>>> >> I created a new shapefile and I toogle to edit. No icons showing in
>>> >> the toolbar that resembled or look like this.
>>> >> http://underdark.wordpress.com/2011/10/21/easy-rectangles-circles-and-ellipses-in-qgis/
>>> >> Any instruction how to make it work in Ubuntu?
>>> >> Thanks.
>>> >> Noli
>>> >> On 10/22/11, Pavol Kapusta <pavol.kapusta at gmail.com> wrote:
>>> >> > Hello,
>>> >> > i would like to introduce you the new Rectangles ovals digitizing
>>> >> > plugin.
>>> >> > This plugin is available in QGIS Contributed Repository and after
>>> >> > installing creates three new objects in Digitizing toolbar: one
>>> >> > multifunction button with digitizing tools, one button for rotation
>>> >> > of
>>> >> > rectangles or ovals and spinbox for changing of number of segments
>>> >> > for
>>> >> > ovals. There are 6 digitizing tools: "Rectangle by extent",
>>> >> > "Rectangle
>>> >> > from center", "Square from center", "Circle from center", "Ellipse
>>> >> > by
>>> >> > extent", "Ellipse from center". Plugin is active only when you are
>>> >> > editing polygon layers. Tools, which have "from centre" in the name
>>> >> > are
>>> >> > able of snapping (after defining in Snapping Options tab of
>>> >> > Settings)
>>> >> > of the virtual center of feature.
>>> >> > "Rotation tool" is functional after selection of (exactly) one
>>> >> > rectangle or oval.
>>> >> > After digitizing of feature, there is Feature form with possibility
>>> >> > of
>>> >> > changing default attribute values. You can deactivate this in
>>> >> > Settings
>>> >> > -> Options -> Digitizing tab -> "Suppress attributes pop-up windows
>>> >> > after each created feature". Option "Reuse last entered attribute
>>> >> > values" is not supported.
>>> >> > I hope you will find this tools useful.
>>> >> > Regards
>>> >> > Pavol
>>> >> > _______________________________________________
>>> >> > Qgis-user mailing list
>>> >> > Qgis-user at lists.osgeo.org
>>> >> > http://lists.osgeo.org/mailman/listinfo/qgis-user
