[Qgis-user] Announcing the Rectangles ovals digitizing plugin - not working in Ubuntu
Saber Razmjooei
razmjooeis at faunalia.co.uk
Wed Nov 9 03:06:36 PST 2011
I think you only need Rectangles oval digitizing plugin (0.1.2)
If you activate/deactivate it from plugin manager, I noticed I had to
restart QGIS.
Cheers
Saber
On Wed, 2011-11-09 at 21:59 +1100, Noli Sicad wrote:
> OK. The inactive green rectangle is showing up again.
> Installing the 0.1.2 Rectangle ovals digitizin plugin.
> I also install the 0.1.6 Rectangle, Ovals, Diamonds.
> What is the difference between these 2 plugins?
> I installed one by one. It did not work. I installed both of the them,
> it also did not work.
> However, it is totally not working in Mac OS X.
> Noli
> On 11/9/11, Noli Sicad <nsicad at gmail.com> wrote:
> > It was inactive. Nothing happened if you drag the rectangle.
> > Now, I uninstalled and installed it again.
> > Now, the icon inactive is gone.
> > It is totally not working in Mac OS X QGIS 1.7.1.
> > I will checked Ubuntu in few minutes. After I download Qt 4.7.4. It is
> > quite big download 1.3G for Mac OS X.
> > http://labs.qt.nokia.com/2011/11/08/qt-4-7-4-release-bundle-for-symbian-news/
> > Thanks.
> > On 11/9/11, Saber Razmjooei <razmjooeis at faunalia.co.uk> wrote:
> >> Select a shape from the toolbar, in the canvas: click and drag.
> >> Cheers
> >> Saber
> >> On Wed, 2011-11-09 at 21:26 +1100, Noli Sicad wrote:
> >>> OK. I saw it. Thanks.
> >>> I am now in Mac OS X.
> >>> My laptop is triple boot :-).
> >>> I toggled the Pencil icon - edit, yet I could not make to change or
> >>> use the defaullt rectangle to draw.
> >>> How do you use this plugin?
> >>> Noli
> >>> > Works for me under Ubuntu 10.04.
> >>> > The icon should be towards the end of your Digitizing toolbar. You
> >>> > need
> >>> > to click on it and hold to see other shapes.
> >>> > Cheers
> >>> > Saber
> >>> > On Wed, 2011-11-09 at 16:38 +1100, Noli Sicad wrote:
> >>> >> This plugin seems not to work with Ubuntu 10.04.
> >>> >> Yes, I checked in QGIS manage plugin. It installed by I could see the
> >>> >> icon and the menu entry in QGIS.
> >>> >> I created a new shapefile and I toogle to edit. No icons showing in
> >>> >> the toolbar that resembled or look like this.
> >>> >> http://underdark.wordpress.com/2011/10/21/easy-rectangles-circles-and-ellipses-in-qgis/
> >>> >> Any instruction how to make it work in Ubuntu?
> >>> >> Thanks.
> >>> >> Noli
> >>> >> On 10/22/11, Pavol Kapusta <pavol.kapusta at gmail.com> wrote:
> >>> >> > Hello,
> >>> >> > i would like to introduce you the new Rectangles ovals digitizing
> >>> >> > plugin.
> >>> >> > This plugin is available in QGIS Contributed Repository and after
> >>> >> > installing creates three new objects in Digitizing toolbar: one
> >>> >> > multifunction button with digitizing tools, one button for rotation
> >>> >> > of
> >>> >> > rectangles or ovals and spinbox for changing of number of segments
> >>> >> > for
> >>> >> > ovals. There are 6 digitizing tools: "Rectangle by extent",
> >>> >> > "Rectangle
> >>> >> > from center", "Square from center", "Circle from center", "Ellipse
> >>> >> > by
> >>> >> > extent", "Ellipse from center". Plugin is active only when you are
> >>> >> > editing polygon layers. Tools, which have "from centre" in the name
> >>> >> > are
> >>> >> > able of snapping (after defining in Snapping Options tab of
> >>> >> > Settings)
> >>> >> > of the virtual center of feature.
> >>> >> > "Rotation tool" is functional after selection of (exactly) one
> >>> >> > rectangle or oval.
> >>> >> > After digitizing of feature, there is Feature form with possibility
> >>> >> > of
> >>> >> > changing default attribute values. You can deactivate this in
> >>> >> > Settings
> >>> >> > -> Options -> Digitizing tab -> "Suppress attributes pop-up windows
> >>> >> > after each created feature". Option "Reuse last entered attribute
> >>> >> > values" is not supported.
> >>> >> > I hope you will find this tools useful.
> >>> >> > Regards
> >>> >> > Pavol
> >>> >> > _______________________________________________
> >>> >> > Qgis-user mailing list
> >>> >> > Qgis-user at lists.osgeo.org
> >>> >> > http://lists.osgeo.org/mailman/listinfo/qgis-user
