[Qgis-user] joining csv file and attribute table
Andreas Neumann a.neumann at carto.net
Fri Nov 25 04:06:31 PST 2011
David,
If you created your data in a spreadsheet you can also save to a dbf
file. DBF has support for numeric data types, so no need for a separate
csvt file.
Openoffice is know to read and write dbf well, so if you have
OpenOffice/LibreOffice at hand, give it a try.
Andreas
On 11/25/2011 11:28 AM, David wrote:
> Hello list
> Thanks to everyone who has helped with this problem so far - unfortunately its not over yet!  Here is a summary:
> 1) created Mac spreadsheet, exported as csv file, joined to attribute table: success
> 2) open 'layer properties' and 'style' tab - whilst all the fields are listed under 'categorised', only those from the original attribute table appear when using 'graduated'.
> 3) made a little .csvt file to define the fields as string, integer, real etc.    This has been checked and corrected but still doesn't work.
> Any idea what I'm doing wrong?   Anyone with experience of transferring data from Mac spreadsheets?
> Thanks in advance
> David Asquith, UK
> Qgis-user mailing list
