[Qgis-user] Problems with saga module interface 0.17
Julien Malik
julien.malik at c-s.fr
Tue Oct 4 03:14:28 PDT 2011
I had the same issue.
Fixed it by taking the packages (saga and python-saga) from
ubuntugis-unstable instead of
https://launchpad.net/~johanvdw/+archive/sagacvs
So :
- aptitude remove saga python-saga
- remove references of https://launchpad.net/~johanvdw/+archive/sagacvs
in your /etc/apt/sources.list.d
- aptitude update
- aptitude install saga python-saga
Should do the trick.
The python bindings package in 2.0.7+svn1156+11~maverick1 is buggy :
I can't import saga from a python interpreter, and get the same "
undefined symbol" error.
Julien
Le 30/09/2011 11:09, Agustin Lobo a écrit :
> Unfortunately, actually still have the problem on another machine,
> also with ubuntu lucid (and with the framework plugin of qgis
> installed):
> The puglin installer states:
> The plugin is broken. Python said:
> /usr/lib/python2.6/dist-packages/_saga_api.so: undefined symbol:
> _ZNK23CSG_Regression_Multiple5Get_REv
> alobo at alobo-laptop:~$ dpkg -l | grep saga
> ii libsaga
> 2.0.7+svn1155+11~lucid1 SAGA GIS development
> files
> ii libsaga-dev
> files
> ii python-saga
> 2.0.7+svn1155+11~lucid1 SAGA GIS python
> bindings
> ii saga
> 2.0.7+svn1155+11~lucid1 System for Automated
> Geoscientific Analyses
> alobo at alobo-laptop:~$ dpkg -l | grep qgis
> ii libqgis-dev 1.7.1-1~lucid1
> Quantum GIS - development files
> ii libqgis1.7.1 1.7.1-1~lucid1
> Quantum GIS - shared libraries
> ii python-qgis 1.7.1-1~lucid1
> Python bindings to Quantum GIS
> ii python-qgis-common 1.7.1-1~lucid1
> Python bindings to Quantum GIS -
> architecture-independ
> ii qgis 1.7.1-1~lucid1
> Geographic Information System (GIS)
> ii qgis-api-doc 1.7.1-1~lucid1
> Quantum GIS API documentation
> ii qgis-common 1.7.1-1~lucid1
> Quantum GIS - architecture-independent data
> ii qgis-plugin-grass 1.7.1-1~lucid1
> GRASS plugin for Quantum GIS
> ii qgis-plugin-grass-common 1.7.1-1~lucid1
> GRASS plugin for Quantum GIS -
> ii qgis-providers 1.7.1-1~lucid1
> collection of data providers to Quantum GIS
> ii qgis-providers-common 1.7.1-1~lucid1
> - architec
> ii qgis-sqlanywhere1.7.1 1.7.1-1~lucid1
> Quantum GIS sql anywhere plugin and
> provider
> Thanks
> 2011/9/22 Agustin Lobo<alobolistas at gmail.com>:
>> That was it, problem solved.
>> Thanks
>> Agus
>> 2011/9/22 Giovanni Manghi<giovanni.manghi at gmail.com>:
>>> Have you installed the "framework processing manager" plugin?
>>> Cheers
>>> -- Giovanni --
>>> On Thu, 2011-09-22 at 10:16 +0200, Agustin Lobo wrote:
>>>> Since few days ago I cannot install the saga module interface 0.17. Qgis claims
>>>> The plugin depends on some components missing on your system. You need
>>>> to install the following Python module in order to enable it:
>>>> processingplugin.processing
>>>> I do have the saga python bindings 2.0.7+dfsg-0.5~lucid
>>>> Any advice on what to do?
>>>> Agus
>>>> _______________________________________________
> Qgis-user mailing list
