[Qgis-user] Question - georeferencing a chart
Laura Leite lauradleite at gmail.com
Fri Oct 7 09:00:24 PDT 2011
This is not a question directly related to QGIS but I can't get it anywhere
(or in too much places leaving me really confused).
I need to georeference a nautical chart (an admiralty chart) and by the
information in it I know the datum (WGS84) and the projection (mercator).
I used the 4 corners and other points from the intersections of the grid in
the nautical chart as GCP
In the end I get the map well positioned but with a small displacement from
other references (a coastline digitized from google earth) and waypoints
marked using a GPS (with WGS84). I have tried with other charts and the
displacement is always more or less the same
What am I missing?
1) Should I make any lat-long corrections. But if I am using the same datum
and projection I assume that no...
2) Should I consider the magnetic declination? But how? I now that the dm to
2011 is 1ยบ 18' W. Should I do something with this value? Isn't it an angle
to mark azimuts or routes?
3) I can't digitize the coastline directly from Google earth? I have used it
more than once (when I don't have any other resources) and until now....
everything was fine.
p.s. - the admiralty chart I am using is the 773. But I have tried others
and I get the same result
many thanks. Hope hearing from you even if it's not a QGIS question....
Laura
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111007/afa1b8c8/attachment.html>
