[Qgis-user] Problem with QGIS importing raster into GRASS
Giovanni Manghi
giovanni.manghi at gmail.com
Mon Oct 10 14:17:25 PDT 2011
I just tested in my Windows Seven 64 bit VM with qgis-dev/osgeo4w and I
cannot replicate it.
Can you share one of the rasters which is causing the crash?
Cheers
-- Giovanni --
On Mon, 2011-10-10 at 13:45 -0700, Hannah Pethen wrote:
> Dear All
> I am experiencing problems importing rasters from QGIS into GRASS
> using the GRASS toolbox in QGIS. Having created a new location and
> mapset, I attempt to import my raster into GRASS using the toolbox in
> QGIS. When I run the r.in.gdal command, the raster is sucessfully
> created but when I click on 'View Output' I get the following error
> message:
> Cannot get map info
> Cannot run module
> command: C:/OSGeo4W/apps/qgis-dev/./grass/modules/qgis.g.info
> info=info rast=TIN280911 at GurobDEM<br>TYPE:-1
> <br>
> GRASS_INFO_WARNING(6068,1): Raster map <TIN280911 at GurobDEM> not found
> GRASS_INFO_END(6068,1)
> GRASS_INFO_WARNING(6068,2): Raster map <TIN280911 at GurobDEM> not found
> GRASS_INFO_END(6068,2)
> GRASS_INFO_WARNING(6068,3): can't read f_range file for
> [TIN280911 at GurobDEM in ]
> GRASS_INFO_END(6068,3)
> GRASS_INFO_ERROR(6068,4): Unable to read range file
> GRASS_INFO_END(6068,4)
> At this point, QGIS stops running and has to be closed.
> I am runnning Windows 7 64 bit.
> Hannah
> Qgis-user mailing list
