[Qgis-user] Problem with QGIS importing raster into GRASS
Carlos Cerdán sig.upagu at gmail.com
Mon Oct 10 14:10:20 PDT 2011
Check your Coordinate Reference Systems, perhaps it isn't same for QGIS
and GRASS location, but you can view both cause you have active "On the
fly projection"
Carlos Cerdán
El 10/10/11 15:45, Hannah Pethen escribió:
> Dear All
> I am experiencing problems importing rasters from QGIS into GRASS
> using the GRASS toolbox in QGIS. Having created a new location and
> mapset, I attempt to import my raster into GRASS using the toolbox in
> QGIS. When I run the r.in <http://r.in.gd>.gdal command, the raster is
> sucessfully created  but when I click on 'View Output' I get the
> following error message:
> Cannot get map info
> Cannot run module
> command: C:/OSGeo4W/apps/qgis-dev/./grass/modules/qgis.g.info
> info=info rast=TIN280911 at GurobDEM<br>TYPE:-1
> <br>
> GRASS_INFO_WARNING(6068,1): Raster map <TIN280911 at GurobDEM> not found
> GRASS_INFO_END(6068,1)
> GRASS_INFO_WARNING(6068,2): Raster map <TIN280911 at GurobDEM> not found
> GRASS_INFO_END(6068,2)
> GRASS_INFO_WARNING(6068,3): can't read f_range file for
> [TIN280911 at GurobDEM in ]
> GRASS_INFO_END(6068,3)
> GRASS_INFO_ERROR(6068,4): Unable to read range file
> GRASS_INFO_END(6068,4)
> At this point, QGIS stops running and has to be closed.
> I am runnning Windows 7 64 bit.
> Hannah
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111010/97119a54/attachment.html>
